Old 07-26-2017, 10:04 PM   #1
Vmax911
Drives: WRB BRZ
E85 OFT tune Bucking/surging
Hey all,
Wondering if you can help me out. I'm experiencing bucking/surging at low(ish) RPM and high throttle. I'm running the OFT 2.076 E85 tune. This is my third tank on E85 this season. Last year I didn't notice this at all. I thought I had bad gas at first, but know that I have filled up twice since the switch so I don't think gas is the issue.
I'll try to link to a log that shows what is going on. I have good fuel trims and IAM is always at 1.0. Any thoughts or suggestions (or what parameters I should log)?
http://www.datazap.me/u/vmax911/buck...zoom=1661-1797
Vmax911 is offline   Reply With Quote
Old 07-27-2017, 04:29 AM   #2
steve99
Drives: FT86
Originally Posted by Vmax911 View Post
Hey all,
Ill say load limits need fixing
Also maf scaling
It running pig rich when you get on throttle, richer than 11 as that limit of stock o2 sensor scaling
The load limits stop it running super rich and very low or retarded timing at high loads low rpm
You dont have total ignition tiking in log but i suspect it will be very low or retarded when you get on throttle coupled with rich it will bog
Old 07-29-2017, 01:14 PM   #3
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
funny thing is I had this a while ago. what I did was clean my K&N drop in filter and that fixed my bogging issues!. It wouldn't hurt to check the filter.
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 07-29-2017, 03:23 PM   #4
Vmax911
Drives: WRB BRZ
Also maf scaling
Thank you for the advice. I've spent some time looking into this "load limit" thing you speak of. It looks like the definitions Shiv provides from OFT does not include the load limit tables for his 2.0xx tunes. I looked around on github and didn't find one that seemed to work with my old 700C tune. I am a bit of a noob at this, so maybe I'm missing something.
However, I did find in your OFT tuning thread where Shiv mentioned to slightly lean out the low RPM/High load open loop fueling table. I will give that a shot.
Here is another log showing the same issue, this time with ignition timing. http://www.datazap.me/u/vmax911/e85-...6&zoom=387-439
It's never a bad idea to check the air filter, I should have thought of this! Thanks for the reminder, I'll check it out.
Old 07-29-2017, 08:12 PM   #5
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Do yourself a favor. PM Wayno and send him a contribution and he will send you all his newest Tunes. I'm running his V124 E85 tune and my car is running like a Raped Ape.
oldgunfan is offline   Reply With Quote
The Following User Says Thank You to oldgunfan For This Useful Post:
zc06_kisstherain (07-31-2017)
Old 07-30-2017, 03:27 AM   #6
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Thanks mate. I've uploaded them all here to make the process a bit faster, instead of messaging back and forth for days.
The Following 3 Users Say Thank You to Wayno For This Useful Post:
oldgunfan (07-30-2017), trvth (08-02-2017), zc06_kisstherain (07-31-2017)
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 08:10 PM
Surging Idle RichardsFRS Issues | Warranty | Recalls / TSB 20 03-16-2016 06:47 AM
2-3K RPM hesitation/bucking - logged 86fun Software Tuning 5 01-29-2016 08:58 AM
Today, my car made a violent bucking sound on start up... lupindub Issues | Warranty | Recalls / TSB 3 11-28-2015 09:27 PM
loss of power/ bucking in rain fasteddy Issues | Warranty | Recalls / TSB 30 10-20-2015 02:08 AM
