Old 09-05-2021, 11:09 PM   #29
garrettjones331
Drives: 2013 Scion FRS
Just curious about the addition of the 2.1 qt of fluid. From reading through the brz manual on the first page it seems like you should be adding more than 2.1 qts each fill/drain. It seems like it's visualized pretty well in the 2nd step of the "C: ADJUSTMENT" Diagram on page PM-70
8) Add fluid through the refill hole until the fluid flows out of the overflow tube.[*6]
9) Wait until the fluid stops flowing and is only dripping.[*7]
10) Temporarily tighten the overflow plug using a 5-mm (0.2 in) socket hexagon wrench and a new gasket.[*8]
11) Add fluid through the refill hole until reaching the specified amount when removing/installing the oil
pan.[*9]
Filling amount (reference):
2.0 L (2.1 US qt, 1.8 Imp qt)
The 2013 FRS manual seems to be a little less ambiguous with the description
(f) Add fluid to the refill hole until it flows out of the overflow
tube. [*5]
(g) Wait until the fluid flow slows and only drops come out. [*6]
(h) Temporarily install the overflow plug and gasket. [*7]
(i) Add fluid to the refill hole using the amount of fluid specified for removal and installation of the oil
pan. [*8]
HINT:
Specified amount of fluid is 2.0 liters (2.1 US qts, 1.8 Imp. qts).
garrettjones331 is offline   Reply With Quote
Old 11-11-2021, 02:48 PM   #30
dodj
Drives: Rallye Blue BRZ
So I took the overflow bolt out and about 1/2 litre of ATF comes out. Wasn't expecting that.
Drivetrain cold. Hadn't run since the day before.
Normal? Or just overfilled from the factory.
Unless, the hotter it gets...the less oil is in the pan?
dodj is offline   Reply With Quote
Old 11-13-2021, 06:43 PM   #31
dodj
Ok. The difference between 71*- ambient... and 108* is about 4 table spoons of fluid.
So....really, getting the correct temp range...really doesn't matter.
Just FYI
Old 04-17-2022, 01:35 PM   #32
NORCAL50
Drives: FRS
pan.[*9]
tube. [*5]
pan. [*8]
HINT:
Thank you, I literally signed up to say this; but you beat me to it. I think I'll be measuring how much comes out and if it's more than 2.1qt, I'll go with the service manual's instructions. Worse case, it'll come out of the overflow.
NORCAL50 is offline   Reply With Quote
Old 04-17-2022, 09:14 PM   #33
Daily86
Daily86's Avatar
Drives: 2017 Toyota 86
I don't know if this helps. Read the manual section that talks about fluid Adjustment.
Sent from my SM-G781U using Tapatalk
Daily86 is offline   Reply With Quote
Old 05-24-2024, 10:13 PM   #34
Kamber
Drives: '22 BRZ | '21 Supra
Has anyone figured out transmission fluid temperature PIDs to use for the 2nd gen cars? I tried the first gen PID posted on page 2 of this thread but no luck with a ScanGauge II on a 2nd gen car. For some reason, jumping pins 4 and 13 does not work for me and I don't get a flashing CEL/fluid detection mode.
Kamber is offline   Reply With Quote
Automatic Transmission Fluid Cooler. ?? connor_lol Engine, Exhaust, Transmission 177 01-02-2023 09:02 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Automatic Transmission Fluid, is this what you use? qijian Engine, Exhaust, Transmission 2 11-30-2017 01:41 AM
AUTOMATIC transmission fluid change DIY?? qijian DIY (Do-It-Yourself) Guides 3 08-31-2017 08:34 AM
AUTOMATIC TRANSMISSION FLUID? How many L ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-21-2015 12:43 AM
