Old 02-26-2020, 02:40 PM   #1
WinnaWinna17
Drives: 2013 Scion FRS, 1998 Sentra SE
Pumping gas takes 10 minutes...
Hi
Has anybody else had this or a similar issue? on 2013 FRS models.
I think something is wrong with my gas pumping hole? The spot where my gas cap screws in to. Either a sensor is missing or some other part removed or missing?
I cannot let the gas pump sit on the auto shut off. The auto lock to hold the gas pumping trigger. It will click off as if it just hit top off in 2 seconds. I have to hold the gas handle trigger in mid pump and it takes over 10 minutes to fill up a whole tank. I cannot even hold the pump at full blast for more than a few seconds.
Just tired of this issue if somebody has a solution
thanks
WinnaWinna17 is offline   Reply With Quote
Old 02-26-2020, 02:57 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Oh no, not another "burping" issue....
Old 02-26-2020, 03:02 PM   #3
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
does this happen at different gas stations? I've had an issue similar to that in the past with this car at a certain pump at a certain gas station.
DandoX is offline   Reply With Quote
Old 02-26-2020, 03:11 PM   #4
WinnaWinna17
Happens at most I can remember
I see there are a few older posts about this issue...
something about a tube getting worn out and falling in or being blocked..
I will call a dealership and see if they have a fix they are aware of
Old 02-26-2020, 03:29 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Let us know what the dealer says; that's pretty odd. Does it do this every single time?
Old 02-26-2020, 03:43 PM   #6
86MLR
86MLR's Avatar
Hold the pump trigger at a slightly different angle.
Old 02-26-2020, 04:07 PM   #7
Collapsed filler tube or plugged evap cylinder filter. Rare but not unheard of.
https://www.ft86club.com/forums/showthread.php?t=118915
Old 02-26-2020, 05:12 PM   #8
WinnaWinna17
Dealership has to order the part for me costing 117$ some kind of hose.
unfortunately it is not under warranty any more so I will have to bring it in and pay them to inspect.
Old 02-26-2020, 05:15 PM   #9
WinnaWinna17
https://www.ft86club.com/forums/show...ht=gas+station
i think this is the issue from similar circumstances. Please pass on any info if you have any.
issue from 2013 models but fixed in later 2013 and beyond...
thanks
Old 02-26-2020, 05:23 PM   #10
StraightOuttaCanadaEh
Wes
Mine always clicks after a few seconds, sometimes it clicks a second time and then I fill up no problem. I usually just move the gas pump out a bit
Instagram: @gt86ws
Old 02-26-2020, 06:33 PM   #11
deca
Drives: Halo 860
I've encountered this issue with a Cooper S, I think it had something to do with the evap system maybe? Instead of just fully inserting the nozzle you had to back it out slightly or the auto shutoff would just engage constantly.
deca is offline   Reply With Quote
FR-S takes 3rd at Targa Newfoundland DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 1 06-11-2015 11:02 AM
Takes a certain person Joeycokeboy Scion FR-S / Toyota 86 GT86 General Forum 61 04-12-2015 06:43 PM
Brakes feel 'stiffer' than usual after pumping 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-14-2014 01:57 PM
Brake travel reduced after pumping 1Cor10:23 Issues | Warranty | Recalls / TSB 0 04-14-2014 09:12 AM
Windshield Fluid not pumping taimysho0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 06-12-2013 12:02 PM
