follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 42
Search took
0.97
seconds.
Search:
Posts Made By:
Donbrz
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
06-29-2016, 09:25 PM
121
Torque RT700 - DOT 4 Racing Brake Fluid - Review
50,213
Posted By
CounterSpace Garage
What juliog stated. We've tested this fluid on a...
What juliog stated. We've tested this fluid on a heavier car with smaller brakes, and more power as well to validate the experience. From that testing, we got some glorious glowing rotor pictures....
Forum:
06-29-2016, 03:10 AM
121
50,213
Posted By
Brzerker
Am gonna give this a try since it's the same...
Am gonna give this a try since it's the same price as the RBF660 at my local fluids shop. The brake pedal is spongy after 2 track days on the RBF660.
Forum:
06-29-2016, 01:27 AM
121
50,213
Posted By
juliog
Yes & Yes.
Yes & Yes.
Forum:
Issues | Warranty | Recalls / TSB
01-03-2016, 09:57 PM
42
PSA: Please stop using the word "void" when talking about warranty and modifications
8,569
Posted By
Packofcrows
damn, i looked for modded pics on google img and...
damn, i looked for modded pics on google img and barely found some front bumper lips.... no modded hahah
Forum:
Engine, Exhaust, Transmission
12-15-2015, 02:50 PM
81
Mishimoto Compact Baffled Oil Catch Can Build Thread!
47,334
Posted By
Mishimoto
Thanks for picking up our catch can setup! The...
Thanks for picking up our catch can setup! The fittings are actually an NPT thread and do not need to be turned completely into the can. Spin the fittings in until they are tight and it should...
Forum:
12-08-2015, 12:13 AM
81
47,334
Posted By
subiebui
I tightened the fittings all the way in, seems...
I tightened the fittings all the way in, seems OK. The small end of the hose should be for the pcv valve and the bigger end goes onto the catch can fitting.
Also if anyone can answer, I still...
Forum:
Southern California
09-29-2015, 03:36 AM
6
86fest photo dump
2,277
Posted By
Terran
Going to post only few here in low-res so that it...
Going to post only few here in low-res so that it doesn't take up too much bandwidth. The rest can be viewed in high-res at this link below:
https://svuong.smugmug.com/86Fest-2015 <--- :thumbup:
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
09-11-2015, 01:32 AM
12
Part Numbers for Tranny & Diff Washer
16,752
Posted By
PWBRZ
Transmission 2 flat washers - 24mm OD x 18mm ID...
Transmission
2 flat washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size)
Belmetric: GA18X24T
Differential
2 crush washers - 24mm OD x 18mm ID x 2mm (drain and fill are same size)...
Forum:
Tracking / Autocross / HPDE / Drifting
09-03-2015, 06:22 PM
76
HPDE Safety Equipment
21,005
Posted By
gatorac
After hearing of the news of the driver killed at an HPDE event at Road Atlanta, The management and Chief Instructors of the group I'm with put our heads together. The conversation was about what we...
Forum:
Southwest
08-04-2015, 01:18 AM
216
3rd Annual Texas FT86 Day Meet/Cruise
44,881
Posted By
Kuri
@exteme You know you want to lead the...
@exteme
You know you want to lead the Houston group again like last year
Forum:
08-03-2015, 10:46 PM
1
O2 Sensor Extender & Spacer
3,703
Posted By
steve99
have a read of the Basic Bolt on Mods link below ...
the spacer in the rear 02 sensor bung will often fool the ecu into not tripping cel code p0420 but will do nothing for power.
the spacers dont...
Forum:
08-02-2015, 08:53 AM
10
LCA vs UCA?
3,257
Posted By
wparsons
RE11A's aren't what I would call really sticky...
RE11A's aren't what I would call really sticky tires, they're a pretty standard street/track tire. Something like the RE71R, Rival S, etc might generate more grip and the alignment could slip, full...
Forum:
Engine, Exhaust, Bolt-Ons
07-26-2015, 05:51 PM
680
Gruppe-S Unequal length header UEL - good power, excellent sound/quality - must SEE!
234,641
Posted By
nunonuna
Always on secondary O2. Never install spacer on...
Always on secondary O2. Never install spacer on primary O2.
Forum:
07-25-2015, 09:04 PM
680
234,641
Posted By
Gruppe-s
Did you install the spacer on both O2 sensors? If...
Did you install the spacer on both O2 sensors? If not, which ones did you do?
Forum:
07-24-2015, 09:23 PM
680
234,641
Posted By
cjm86
I installed the o2 spacer about a month ago or...
I installed the o2 spacer about a month ago or so and have not had a cel turn on yet. Maybe about 1500 miles
Forum:
07-24-2015, 09:15 PM
680
234,641
Posted By
Snyperiflex
Yes I attend meets in Houston, you're welcome to...
Yes I attend meets in Houston, you're welcome to hear my car
No dynos done
Sent from my SM-N910T using Tapatalk
Forum:
07-22-2015, 05:07 PM
313
Offical Gruppe-S UEL Header Install & Review Thread
146,213
Posted By
Gruppe-s
I am working with a big company to try and offer...
I am working with a big company to try and offer a solution. The reflective gold tape that you can apply easily doesn't reflect enough heat. I will have a cost effective solution for your pan that is...
Forum:
07-11-2015, 08:47 AM
21
Poor Overpipe Clearance
6,505
Posted By
nunonuna
You may check this area too as shown in the...
You may check this area too as shown in the pictures.
If the gap of indicated area is less than 1/4" when its cool, that is most likely where the noise comes from because metal expands after heat...
Forum:
07-10-2015, 06:22 PM
48
Quiet Headers?
22,622
Posted By
DAEMANO
Benefits of a OEM header with gutted cat and...
Benefits of a OEM header with gutted cat and straight pipe are:
1. Price. A take-off OEM header sells for $75-$125. Buy it, gut it and keep your orginal header for smog check swaps.
2. Power. The...
Forum:
07-10-2015, 01:13 PM
48
Quiet Headers?
22,622
Posted By
DAEMANO
Probably will. You can reset it with any OBD II...
Probably will. You can reset it with any OBD II tool, but it will pop up again eventually. Better to get a tune because you won't get the most out of a catless header without one. OpenFlashTablets...
Forum:
07-08-2015, 04:01 PM
680
234,641
Posted By
Gruppe-s
I am having a local guy test the header with a...
I am having a local guy test the header with a CEL FIX O2 extender, let you know what he says.
Forum:
07-08-2015, 04:15 AM
680
234,641
Posted By
Andrew025
Pretty much every header has spots for both the...
Pretty much every header has spots for both the sensors.
There is normally a cat between the two sensors, which is why catless may or may not throw a code based a few factors (like spacing).
Don't...
Forum:
07-01-2015, 11:28 AM
616
PTUNING 4-1 Full T304 SS Equal Length Double-Slip Race Header (200+whp 93 pump gas)
246,110
Posted By
s30series
DEI Ti wrap ...
DEI Ti wrap
https://www.designengineering.com/category/catalog/dei-cycle/motorcycle-exhaust-pipe-wrap-kits/titanium-exhaust-wrap-lr-technology
Forum:
06-30-2015, 02:27 PM
680
234,641
Posted By
Gruppe-s
Did you confirm that I didn't send you the wrong...
Did you confirm that I didn't send you the wrong ones?
Forum:
04-28-2015, 12:00 PM
30
New aFe Takeda Momentum Carbon Fiber Intake System For 13-15 Scion FR-S & Subaru BR-Z
23,329
Posted By
aFe POWER
As "Wise and PNW FRS" suggested it is a partial...
As "Wise and PNW FRS" suggested it is a partial bumper detachment making it easier to remove the snorkel with enough given room. The instructions should provide you with enough help to do this.
Forum:
04-28-2015, 01:40 AM
30
23,329
Posted By
Wise
I have the Version 2 aFe Takeda intake which...
I have the Version 2 aFe Takeda intake which looks similar in install to this version.
The install pamphlet told me to remove the bumper to unbolt and take out the snorkel assembly of the stock...
Forum:
04-27-2015, 11:49 PM
30
23,329
Posted By
PNW FRS
Visit their website... there are install...
Visit their website... there are install instructions (PDF) available. Looks like there is a "partial" removal of the bumper in order to remove the OEM snorkel.
Forum:
04-05-2015, 11:06 PM
5
HKS Hi Power Spec L at 3,4&5k Rpms
4,751
Posted By
EvoPrecision8
Here's my HKS Spec L with Tomei front pipe. ...
HKS Spec L + Tomei Type 60 Cold Start | Subaru BRZ - YouTube
The Spec L alone wasn't doing it for me. It was alright under load and on deceleration,...
Forum:
04-05-2015, 07:15 PM
5
4,751
Posted By
Decay107
I had the Spec-l for a while, sounded great until...
I had the Spec-l for a while, sounded great until I added a header.
Forum:
03-25-2015, 04:49 PM
2
HKS Spec L Catback Lightweight vrs Original
1,242
Posted By
Koa
Don perhaps you are failing to understand that...
Don perhaps you are failing to understand that there is no straight cut answer to this and I am showing you the available resources available to you to be able to answer the question.
Refer to...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
12:21 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
