Drives: 2015 Brz Blue Series
O2 Sensor Extender & Spacer
Reading that O2 sensor extenders and spacers can be used to run a catless header on brz/frs without throwing a CEL code, in the absence of a tune. Any experience or insights into effectiveness of extenders and spacers on our engines would be appreciated.
#2 | |
the spacer in the rear 02 sensor bung will often fool the ecu into not tripping cel code p0420 but will do nothing for power. the spacers dont always work and sometimes the code will still trip but maybe less frequently. you rearly need a tune or your wasting most of the gain available from catless headers. |
| Tags |
| o2 extenders |
| DIY: Oxygen sensor spacer | Hardrock4445 | DIY (Do-It-Yourself) Guides | 13 | 07-11-2015 11:43 AM |
| FS: o2 sensor extension harness, o2 bung with plug, o2 spacer | B-R-Z | Engine, Exhaust, Bolt-Ons | 1 | 11-29-2014 02:44 PM |
| Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? | Khorne | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-03-2014 12:53 PM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
| 25mm conversion spacer with 5mm spacer = safe or unsafe? | deedz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2013 11:59 AM |
