follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 5
1
2
3
4
5
Showing results 1 to 30 of 148
Search took
0.38
seconds.
Search:
Posts Made By:
Spacemane969
Forum:
BRZ Second-Gen (2022+) -- General Topics
03-22-2022, 05:05 AM
170
2022+ BRZ STi Parts and Accessories Thread.
56,263
Posted By
danson
Metallic. Its the same "Magnetite Grey Metallic"...
Metallic. Its the same "Magnetite Grey Metallic" that is available for the rest of the Subaru family.
Forum:
03-19-2022, 10:38 AM
170
56,263
Posted By
danson
Heres a couple of mine. The front lip didnt ship...
Heres a couple of mine. The front lip didnt ship with the hardware kit, so Im working with a local body shop who can supply the correct well nuts for install. The official hardware kit from subaru is...
Forum:
GR86 General Topics (2nd Gen 2022+ Toyota 86)
02-03-2022, 06:54 AM
22
GR86 in TRD body kit walk around
6,074
Posted By
86man
In red? ...
In red?
https://www.youtube.com/watch?v=iR3gbi8ooJY
Forum:
01-10-2022, 12:47 PM
35
Pavement GR86 or Ice Silver BRZ?
14,465
Posted By
dreamwonder
Stock suspension on FRS oem 17" wheels with over...
Stock suspension on FRS oem 17" wheels with over sized winter tires, 235/45.
Forum:
12-06-2021, 12:41 PM
588
The Gen 2 Photo Thread
180,352
Posted By
Simmons
Some pics my friend took for me.
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
11-30-2021, 08:10 AM
2
Trade in values vs. List price
1,472
Posted By
There are low mileage recent model years selling...
There are low mileage recent model years selling (actually selling not just asking) for at or even slightly above what was originally paid for on them.
Unfortunately mileage still rules even in...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
01-23-2021, 10:09 PM
1
Melted winjet headlight connector cause for concern?
281
Posted By
soundman98
not likely any more of a problem outside of that...
not likely any more of a problem outside of that connector.
replace the connector, it should be fine.
Forum:
11-18-2020, 09:07 AM
540
Subaru previews next-generation BRZ, announces November 18th unveiling date
112,973
Posted By
Spuds
https://youtube.com/watch?v=FQerjHPcaL0 2.4...
2.4 NA D4S, 228hp 184ftlb
Nominal torque curve at 2:18 btw
Forum:
Issues | Warranty | Recalls / TSB
05-16-2020, 02:27 AM
6
Play in SPC LCA bushing
972
Posted By
strat61caster
That's the spherical joint in the wheel hub, not...
That's the spherical joint in the wheel hub, not the spc lca, it's supposed to have multiple degrees of freedom. As long as you don't have unusual noises back there it's probably fine.
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
05-08-2020, 05:02 PM
4,440
Sticky:
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
1,154,217
Posted By
solidONE
Camber bolts keep their position. People have...
Camber bolts keep their position. People have been beating on it with adjusted camber from eccentric bolts since 2012. Not an issue.
There is more room for error, but It's not hard when you have...
Forum:
05-07-2020, 12:04 AM
4,440
Sticky:
1,154,217
Posted By
BlueWhelan
Might I suggest using both - make identical...
Might I suggest using both - make identical adjustments using the camber plates, then zero the settings in using the bolts. That way you keep the SAI identical side to side. Also, if you ever...
Forum:
04-24-2020, 11:46 AM
4,440
Sticky:
1,154,217
Posted By
solidONE
6K in the rear with the right amount of damping...
6K in the rear with the right amount of damping pressure can be comfortable and even ride like a boat. 5K~6K range is a good range for spirited street, IMO. 8K is far from mild on this car. The main...
Forum:
04-22-2020, 09:17 AM
4,440
Sticky:
1,154,217
Posted By
Racecomp Engineering
5k front and 8k rear is a pretty aggressive rear...
5k front and 8k rear is a pretty aggressive rear bias. Those that do run that much rear bias in spring rate usually have a clutch LSD that behave differently than the OEM LSD.
For the spring...
Forum:
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
12-30-2019, 07:10 PM
6
"duct" panel near underbody is loose and rattling
2,190
Posted By
EndlessAzure
Yes. Those are the radiator air guides. The...
The driver one is held on by two clips actually. One large pop clip to the plastic undertray and one small clip into the crash beam/frame (you can actually...
Forum:
12-18-2019, 10:23 AM
1,654
Failure After J02 Recall - Discussion Threads
389,466
Posted By
What are they planning to do for $17,000 that...
What are they planning to do for $17,000 that does not involve manufacturing a new car?
Forum:
Off-Topic Lounge [WARNING: NO POLITICS]
11-06-2019, 03:36 PM
20
Questions about a personal car insurance claim.
3,049
Posted By
Dave-ROR
What if you have $0 ded on a collector car...
What if you have $0 ded on a collector car policy!?!?! ;)
OP: Yes, they will cut you a check so you can buy a used fender to save money. They have preferred shops they'll deal with directly but...
Forum:
11-06-2019, 10:47 AM
20
3,049
Posted By
You should always be able to pick the shop of...
You should always be able to pick the shop of your choice, Insurance can't dictate that, at least not in any state I ever lived in. They may refer you to a specific shop or give you an added...
Forum:
09-30-2019, 04:08 PM
46
I don't understand coilover spring rates.
14,582
Posted By
Westen86
According to this...
According to this https://www.ft86club.com/forums/showthread.php?t=8739
...the Cusco and RS*R coilovers have a near stock or comparably softer rate. Stiffer rear and under 6k
Forum:
09-28-2019, 08:47 AM
46
14,582
Posted By
Goingnowherefast
Here's a good read about selecting spring rates:...
Here's a good read about selecting spring rates: http://speed.academy/how-to-choose-spring-rates-eibach-koni-marcor/3/
Forum:
09-28-2019, 04:30 AM
46
14,582
Posted By
Grey86
It honestly depends on the damping, i not long...
It honestly depends on the damping, i not long installed coilovers with 6k front and rear and they feel exactly like stock when fully on soft damping if not softer. There are coilovers out there that...
Forum:
09-18-2019, 09:22 PM
15
Does anyone know the length of the stock front sway end links?
5,218
Posted By
wparsons
5/8" difference left to right is pretty huge, I'd...
5/8" difference left to right is pretty huge, I'd look into what's happening there. Was it on perfectly flat ground with no extra weight in the car?
The end link lengths should be set to remove...
Forum:
09-12-2019, 05:37 PM
15
5,218
Posted By
Leonardo
front looks like 9" & 5/8ths from ball joint to...
front looks like 9" & 5/8ths from ball joint to ball joint. rear is 3" & 5/8ths
https://i.imgflip.com/3aepg4.jpg (https://imgflip.com/i/3aepg4)
Forum:
09-12-2019, 03:58 PM
15
5,218
Posted By
wparsons
At resting height you want the blades of the sway...
At resting height you want the blades of the sway bar level with the ground. Adjust the end links so that it's level and no twisting force applied at resting height. Chances are high that they'll...
Forum:
09-12-2019, 02:41 PM
15
5,218
Posted By
Code Monkey
This may help: linky
This may help:
linky
Forum:
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
08-27-2019, 05:27 AM
2,561
Pic of your GT86 - RIGHT NOW!
828,023
Posted By
Raven86Project
https://i.imgur.com/qYziBPe.jpg
Forum:
07-05-2019, 06:27 PM
2,561
828,023
Posted By
Thunder86
Did a mini photoshoot after work. Happy Friday...
Did a mini photoshoot after work. Happy Friday everyone!
Forum:
06-24-2019, 09:19 PM
7
Clunk/Pop in front drivers side end while reversing
2,335
Posted By
NyX_Nick
I just had this issue, my car is lowered on Tein...
I just had this issue, my car is lowered on Tein Flex Z's. It showed up after the winter so I thought it was coil bind, or possibly end links. Both of those turned out to be non-issues and everything...
Forum:
05-22-2019, 10:50 AM
375
"Landmark" FR-S Photos from Around the World
226,926
Posted By
Your car is cock blocked!
Forum:
04-29-2019, 05:17 PM
10
Swap horn for Toyota/Lexus
2,669
Posted By
Other Subaru horns may be.
Forum:
04-16-2019, 02:34 PM
87
Front windshield replacement cost
68,104
Posted By
Millions. Insurance won't cover that since it...
Millions.
Insurance won't cover that since it is just normal wear and tear. It has to be broken in a manner that can not be repaired before most insurance companies will even touch it.
The joys of...
Page 1 of 5
1
2
3
4
5
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Site Announcements / Questions / Issues
05:29 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
