Old 04-29-2019, 03:51 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Swap horn for Toyota/Lexus
I think this car deserves a much more mature and elegant horn based off of its looks. I plan to go junk yard picking for other horns. I've seen a few videos on swaps for louder horns but nothing fancy.
Do you guys think Toyota and Lexus horns would be plug and play? Same wiring etc.
Spacemane969 is offline   Reply With Quote
Old 04-29-2019, 03:56 PM   #2
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Just get hella horns for 30$
Sent from my ONEPLUS A6013 using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 04-29-2019, 04:13 PM   #3
wparsons
wparsons's Avatar
Might not be plug and play, but if you can swap the plug (if needed), then it'll work fine.
flickr
Old 04-29-2019, 05:17 PM   #4
Other Subaru horns may be.
Spacemane969 (04-29-2019)
Old 04-29-2019, 05:24 PM   #5
Strife26
Strife26's Avatar
Hella horns aren't plug in play. Not the ones I bought, but it took me 5m to figure it out and there are videos online that give enough guidance to figure it out if you're the technical type. Pm if you go that route and need help.
Old 04-29-2019, 06:24 PM   #6
Spacemane969
Thanks. I assume it's just cut and crimp.
The Following User Says Thank You to Spacemane969 For This Useful Post:
YamahaR86 (04-30-2019)
Old 05-12-2019, 11:50 AM   #7
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Find some 80’s Cadillac horns.
Those sound like a bloody locomotive at a level crossing.
Muskoka800 is offline   Reply With Quote
Old 05-12-2019, 12:21 PM   #8
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I've gone through two different horn setups on my BRZ. The first was the Cadillac 4-Note setup, which sounded lovely:
That wasn't quite loud enough for me, though, so I eventually went insane, and upgraded to my current setup, which is probably a little bit overkill for most folks.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
bcj (05-12-2019)
Old 05-12-2019, 03:29 PM   #9
MrDinkleman
Drives: 2016 Oceanic, "base" model
PNP possible but not probable?
Back in 2011, I replaced my Yaris' single horn with a pair of IS300 hi/lo horns. I happened to find a "Y" harness adapter kit, with Toyota part numbers, on ebay from Japan. It had Toyota connectors and Toyota horns. Other than removing the bumper cover it was easy-peasy. Sounded great, too.
But I've never seen those parts or the seller since.
I was hoping to do the same with my FRS and contemplated taking the horn kit off of the Yaris, when it got totaled (which led me to buy the FRS). But then i realized the car is built by Subaru. So the connector in the car probably wouldn't be compatible with the connectors on the horns.
So, basically you'll have to buy two Toyota horn plugs and make your own "Y" harness. Then you need to buy the horns. Of course, you can just snip the connectors from a junkyard car when you get the horns but then it's not PNP anymore...
MrDinkleman is offline   Reply With Quote
Old 02-04-2022, 03:36 PM   #10
Shurlokep
Shurlokep's Avatar
Drives: CRV
You can go to a junkyard and look for larger cars. But if you want something that will make your car sound extraordinary, find horns from the 80’s Cadillac or Buick. They usually produced four notes instead of two like most cars do nowadays. The notes are usually A, C, D, and E. They are printed on each horn. The wiring shouldn’t be a problem as there’s only one wire coming out of all GM horns. These are some of the loudest car horns you can find.
Shurlokep is offline   Reply With Quote
Old 02-05-2022, 03:33 AM   #11
gpvecchi
gpvecchi's Avatar
I have the JDM Subaru aftermarket horns for Forester, they are almost plug'n play. You have just to rotate the bracket on one and the plastic on the other.
gpvecchi is offline   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
norcalpb (02-07-2022)
The Lexus IS300 (welded) Differential swap. cheeseburger Engine, Exhaust, Transmission 12 04-19-2019 03:39 AM
Lexus/FRS differential pumpkin swap: Y31 casing sfruski Engine, Exhaust, Transmission 5 09-11-2018 12:33 PM
Lexus is300 diff swap M98 3.91 ogrowup Engine, Exhaust, Transmission 5 02-28-2017 10:45 AM
Toyota left a nice surprise if you're doing a Toyota motor swap.. Manji Engine Swaps 15 01-07-2015 01:48 AM
Lexus badge swap bdanisi Scion FR-S / Toyota 86 GT86 General Forum 61 03-26-2013 02:07 AM
