follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 5
1
2
3
4
5
Showing results 1 to 30 of 130
Search took
0.82
seconds.
Search:
Posts Made By:
stevo585
Forum:
Engine, Exhaust, Transmission
03-14-2017, 11:04 AM
5
PCV valve thread size
2,494
Posted By
BRZoomTX
Can't recall the exact thread size right now, but...
Can't recall the exact thread size right now, but I ordered a fitting from summit racing. When I get my block back (getting built) I'll follow up with the fitting size I used. Its an open adapter...
Forum:
03-13-2017, 07:36 PM
5
2,494
Posted By
mrk1
I drilled out the valve, pretty straight forward
Forum:
02-27-2017, 10:29 PM
78
Installed 3.91 rear diff from Lexus is300- amazing
32,279
Posted By
mrk1
3.73 is possible but harder to come across then...
3.73 is possible but harder to come across then the 3.91
Forum:
Forced Induction
02-05-2017, 01:51 PM
42
SBD400X turbocharger
21,762
Posted By
xuimod
I have the SBD kit. Its ok but looking to...
I have the SBD kit. Its ok but looking to uninstall it and perhaps get a different FI kit.
I have had too many issues with exhaust leaks and carbon monoxide leaking into the cabin. The quality...
Forum:
Forced Induction
01-30-2017, 11:12 PM
11,295
Full throttle Electric Supercharger Build Thread
3,460,794
Posted By
Sojhinn
Already working on it Sent from my iPhone...
Forum:
Forced Induction
01-21-2017, 08:32 PM
1,346
JDL turbo kit owners thread
491,218
Posted By
Amputechture
They are, I have their fan shroud and my turbo...
They are, I have their fan shroud and my turbo blanket rubs against the fan motor. No way in hell the factory fan setup will fit.
Forum:
Forced Induction
01-13-2017, 06:45 PM
42
21,762
Posted By
Amputechture
Gotcha. Yeah the longer charge piping version...
Gotcha. Yeah the longer charge piping version didn't exist when I made my purchase. To me the MAF placement is no different than Greddy/SBD/Full Race/MAPerformance :iono: No hard feelings harbored...
Forum:
Software Tuning
01-08-2017, 08:43 PM
6
Re-pin ODB port
2,782
Posted By
Fizz
I had this exact problem recently with my ecutek...
I had this exact problem recently with my ecutek cable. What I did was to use one of those cheap OBD2 extension cables with (mine had an on/off switch) in between the car's OBD port and and ecutek...
Forum:
Software Tuning
01-08-2017, 07:25 AM
6
Re-pin ODB port
2,782
Posted By
steve99
Also try bending both rows of pins on the ecutek...
Also try bending both rows of pins on the ecutek cable slightly inwards towards the centreline of the plug, use something like an old full size SD card to bend the pins
Forum:
Software Tuning
01-07-2017, 10:34 PM
6
Re-pin ODB port
2,782
Posted By
TofuJoe
I had issues with a flaky ECUTek connection....
I had issues with a flaky ECUTek connection. Here's what worked for me - a $10 fix.
http://www.ft86club.com/forums/showpost.php?p=2802767&postcount=53
Worth a try before re-pinning.
Forum:
Forced Induction
01-07-2017, 11:13 AM
42
21,762
Posted By
Alltezza
It's increased now to 3600 starting off. They...
It's increased now to 3600 starting off. They said something about after new years they're making changes to their kit. Not sure if that's what it is or not.
Forum:
Forced Induction
12-10-2016, 06:38 PM
1,206
Phantom FTS Electric Supercharger Owners Thread
362,124
Posted By
Sojhinn
I think aux charger would be best. Sent...
Forum:
Forced Induction
12-01-2016, 03:12 PM
11,295
3,460,794
Posted By
Target70
I can't see the video at work but if it is the...
I can't see the video at work but if it is the old sequential setup Rob tried, then yeah, I remember it was more boost than you could safely run stock: motor, fuel, clutch all start becoming a...
Forum:
Forced Induction
12-01-2016, 07:26 AM
11,295
3,460,794
Posted By
Reamer
My guess for the easiest way to tune would be to...
My guess for the easiest way to tune would be to use something like Delicious Tuning's "FNG" tune so you don't have to worry about the MAF. However, I know nothing in this area so I could be way off....
Forum:
Forced Induction
11-26-2016, 02:40 PM
1,206
362,124
Posted By
vfrqqq
These are the steps I took to disassemble my...
These are the steps I took to disassemble my compressor unit and apply some liquid silicone sealant to keep the motor plate from twisting with respect to the compressor housing. I don’t know how...
Forum:
Forced Induction
11-18-2016, 05:34 PM
11,295
3,460,794
Posted By
fenton
Upgrade time? :) Great work:thumbup: To...
Upgrade time? :)
Great work:thumbup:
To those asking for a list, i will post one up this weekend. Keep in mind there has not been any shipments for some time.
This will be the first place...
Forum:
Forced Induction
10-27-2016, 04:13 AM
9,139
Innovate (Sprintex) Supercharger Owners Topic
2,845,358
Posted By
Kodename47
You'd be daft to run a 335 without one IMO. They...
You'd be daft to run a 335 without one IMO. They get very hot.
There are ways to monitor the charge temps, I run a separate IAT sensor in the manifold. It's quite common on the kits here in...
Forum:
Forced Induction
10-25-2016, 09:31 AM
9,139
2,845,358
Posted By
Xero-Limit
If you have e85 then the cooling matters very...
If you have e85 then the cooling matters very little since e85 does not have the same knock issues pump gas does. Street use on 93 and the 69 or 70mm is fine, but running on track or repeated pulls...
Forum:
Forced Induction
10-23-2016, 07:54 PM
9,139
2,845,358
Posted By
ajcarson11
I don't think i've ever really experienced...
I don't think i've ever really experienced heat-soak on my non-intercooled. Then again, I'm just daily driving on 93 and only doing pulls every now and then. I live in Indiana where the temperature...
Forum:
10-17-2016, 08:59 PM
40
CSG Mike's 2017 Baseline dynos
14,442
Posted By
CSG Mike
It's difficult to make a blanket statement...
It's difficult to make a blanket statement without being able to actually tune the car, but at 13:1, there was zero knocking on ACN91.
Is there more power that can be had running slightly richer? ...
Forum:
Forced Induction
09-04-2016, 10:45 PM
36
What does xxx WHP feel like?
11,072
Posted By
FRS Justin
How about a video instead of a slip 13 47...
13 47 frs - YouTube
Copy of 13.58 FRS Pass - YouTube
I have ran as fast as a 104 trap and my 60ft n/a 1.79 was my best 13.5 was a 1.82 I believe. My...
Forum:
Forced Induction
08-01-2016, 10:35 PM
11,295
3,460,794
Posted By
silent runner
I see you guys need to play, and I'll shut up...
I see you guys need to play, and I'll shut up about worrying too much about the next upgrade.:lol:
Thought I might post a little picture of the car that will inherit my V1., Phantom Supercharger....
Forum:
Forced Induction
08-01-2016, 04:11 PM
1,206
362,124
Posted By
Sojhinn
More info soon. 😁 Sent from my iPhone...
More info soon. 😁
Forum:
Forced Induction
08-01-2016, 02:04 PM
11,295
3,460,794
Posted By
Sojhinn
Latest test logs: ...
Latest test logs:
http://uploads.tapatalk-cdn.com/20160801/d8b9e4261b9af79d486cccacb7e43099.png
http://uploads.tapatalk-cdn.com/20160801/faf23e00a31d5a68db4db3652fcad440.png
More info soon.
Forum:
Forced Induction
08-01-2016, 01:44 PM
11,295
3,460,794
Posted By
DaBozz88
Thanks for all the info, I had already sent in an...
Thanks for all the info, I had already sent in an email for a developer kit, with no response. Thats how I got to here. Fabricating the wiring and ductwork/piping wouldn't be an issue.
When I ask...
Forum:
07-24-2016, 10:04 AM
0
FA-20 engine and transmission weights
5,452
Posted By
seant2h
I am in the process of disassembling and parting out two FA-20's and I thought I'd add some info on weights of the major components:
Short block with crank, rods and pistons: 90 lbs
Transmission...
Forum:
Software Tuning
07-15-2016, 12:30 AM
14
AFR accurate on Torque App?
8,236
Posted By
steve99
torque app should work fine, are you...
are you using 02 sensor 1 bank 1
suspect you logging incorrect sensor
the update rate on torque can be a bit slow.
Forum:
Forced Induction
07-13-2016, 10:29 PM
11,295
3,460,794
Posted By
Blu-by-U
Or both AT's. Apples to apples and oranges to...
Or both AT's. Apples to apples and oranges to oranges. Apple to oranges only tells you which make a better pie.
Forum:
Forced Induction
07-13-2016, 06:35 PM
11,295
3,460,794
Posted By
DAEMANO
Finally I went back and found the Phantom ESC vs....
Finally I went back and found the Phantom ESC vs. KW Supercharger video and post. Keep in mind this is both cars running on e85.
The Phantom launches harder and holds it's lead till about 4k RPM...
Forum:
Forced Induction
07-12-2016, 05:41 PM
11,295
3,460,794
Posted By
DAEMANO
Thanks for finally chiming in Sojhinn. What I...
Thanks for finally chiming in Sojhinn. What I also find to be important about this, but difficult to point out, is that, from a roll or from a dig you had nlowell for the first 5-7 seconds of the...
Page 1 of 5
1
2
3
4
5
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
09:23 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
