Old 03-12-2017, 11:56 PM   #1
stevo585
Drives: White 2014 BRZ
PCV valve thread size
I want to VTA. Looking for a fitting to replace the oem pcv.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 03-13-2017, 07:36 PM   #2
mrk1
Drives: Sterling BRZ Ltd
I drilled out the valve, pretty straight forward
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
stevo585 (03-17-2017)
Old 03-14-2017, 11:04 AM   #3
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Can't recall the exact thread size right now, but I ordered a fitting from summit racing. When I get my block back (getting built) I'll follow up with the fitting size I used. Its an open adapter that runs straight to my radium catch can on the pass side, then vents to atmosphere.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
Old 03-25-2018, 11:58 AM   #4
sid94
Drives: 2013 frs
Did you ever confirmfitting size? Doing same as op but don’t want to drill out my pcv
sid94 is offline   Reply With Quote
Old 04-14-2019, 09:46 PM   #5
kill3rwill
Drives: 13 brz
bump? im curious too. Should be the same as an sti's but nasioc is no help either
kill3rwill is offline   Reply With Quote
Old 04-15-2019, 10:40 AM   #6
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Thread size is 3/8 BSPT.
Jeff@Racer X Fab is offline   Reply With Quote
Thread size for BRZ / FRS Antenna Uniquedetail Cosmetic Modification (Interior/Exterior/Lighting) 5 10-10-2016 03:27 PM
The divide your age by your penoose size thread Icanfaptothis86 Off-Topic Lounge [WARNING: NO POLITICS] 40 12-10-2015 12:55 PM
Looking for Bolt/thread size Mundy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-14-2015 08:48 AM
FA20 oil cap thread size? tomato86 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-28-2014 12:04 PM
What is our lug nut thread size? LeeMaster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-21-2013 06:30 PM
