follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 42
Search took
2.39
seconds.
Search:
Posts Made By:
Bodalenko
Forum:
Forced Induction
10-08-2022, 04:44 AM
1,372
Harrop TVS86 Owners Thread
394,731
Posted By
grumpysnapper
I changed my plugs about 2000km ago as a belts...
I changed my plugs about 2000km ago as a belts and braces thing when I put in new Ignition Projects coil packs.
Just used the recommended OEM plugs, and they are fine.
I use the dual Radium kit...
Forum:
Engine, Exhaust, Transmission
09-03-2021, 07:43 PM
6
Verus CF driveshafts.
1,235
Posted By
StraightOuttaCanadaEh
With any aftermarket driveshaft, diff and...
With any aftermarket driveshaft, diff and subframe bushings cause a change in pinion angle and vibration at around 80 mph. Stock cars don't seem to have this issue.
Forum:
Forced Induction
02-15-2021, 08:29 PM
1,372
394,731
Posted By
CSG Mike
low speeds or low load? At very low load,...
At very low load, all the driving is on DI.
The moment where it transitions to DI + PI, with minimal PI, is when the 1050X really shines.
Forum:
Forced Induction
01-23-2021, 12:16 AM
1,372
394,731
Posted By
Irace86.2.0
I suppose, but the ports could be off or mixed...
I suppose, but the ports could be off or mixed with the direct injectors in a way where, when they are at short pulses, they are contributing just a fraction of the total fuel quantity.
It is...
Forum:
Forced Induction
01-22-2021, 09:06 PM
1,372
394,731
Posted By
Irace86.2.0
I don't have experience with this, but I would...
I don't have experience with this, but I would imagine it would depend on the tuner as well. For instance, DW700s could be worse at low load like Mike said, but if the tuner doesn't use them that...
Forum:
Forced Induction
01-10-2021, 01:06 AM
1,372
394,731
Posted By
Irace86.2.0
He was referring to oil and blowby gases getting...
He was referring to oil and blowby gases getting into the supercharger and getting trapped in the heat exchangers. The Harrop kit routes the PCV to the front of the supercharger, so there will be oil...
Forum:
Forced Induction
07-07-2020, 11:49 AM
1,372
394,731
Posted By
Irace86.2.0
It was aesthetics. I routed them under the...
It was aesthetics. I routed them under the supercharger to the back then they follow the same path as the Edelbrock kit. I also mounted the coolant pump next to my battery to better position the pump...
Forum:
Forced Induction
06-27-2020, 06:32 AM
1,372
394,731
Posted By
grumpysnapper
I just went with the alloy Whiteline, but had it...
I just went with the alloy Whiteline, but had it powder coated black. Plenty of room for the Harrop.
But as was pointed out above, the existing diagonal braces do the real work...and the strut brace...
Forum:
Forced Induction
06-26-2020, 10:29 PM
1,372
394,731
Posted By
Kiske
Here is Sti's sales pitch on their flexible bars....
Here is Sti's sales pitch on their flexible bars. The tS BRZ models also include flexible V-braces.
https://www.sti.jp/en/parts/feature/flexibletowerbar.html
Forum:
Forced Induction
06-25-2020, 09:09 AM
1,372
394,731
Posted By
Irace86.2.0
STI is suppose to be best but whatever you like....
STI is suppose to be best but whatever you like. They are cosmetic with a little effect.
Forum:
Forced Induction
06-23-2020, 07:59 PM
1,372
394,731
Posted By
Kiske
Tanabe/Revell make a dual before/after temp gauge...
Tanabe/Revell make a dual before/after temp gauge for iat. It includes 2 bungs. You could tap the blower runner and intake piping to get a live before and after air temps.
There are quote a...
Forum:
Forced Induction
06-21-2020, 08:33 PM
1,372
394,731
Posted By
grumpysnapper
Just to be clear I have had zero vibration...
Just to be clear I have had zero vibration problems with either the alloy or carbon driveshafts, they have both functioned perfectly. Noise transfer has been the complicating factor.
During many...
Forum:
Forced Induction
06-18-2020, 11:16 PM
1,372
394,731
Posted By
86TOYO2k17
Bodalenko My zeitronix FF kit is only wired to...
Bodalenko
My zeitronix FF kit is only wired to the rear o2 plug in, and one extra wire to a ground.
Forum:
Forced Induction
06-18-2020, 11:10 PM
1,372
394,731
Posted By
86TOYO2k17
Bodalenko Zero added NVH with my DSS carbon...
Bodalenko
Zero added NVH with my DSS carbon fiber DS, both before and after engine mounts, trans insert, rear diff inserts, na, and fi.
I think i did fluidampr crank pulley at same time. As well...
Forum:
AUSTRALIA
08-28-2019, 08:59 PM
22
Stock clutch replacement, how much have you paid?
6,464
Posted By
fuddbutter
They suggested the exeedy, offered me that or the...
They suggested the exeedy, offered me that or the stock, it was not much more than stock so thought i'd go with it.
I could have gotten away with not changing it, my throwout bearing had collapsed,...
Forum:
Issues | Warranty | Recalls / TSB
07-15-2019, 07:08 PM
21
Shopping for aftermarket clutch release bearing
4,728
Posted By
solidONE
Appreciate the input. I keep seeing the UREA...
Appreciate the input. I keep seeing the UREA grease that Honda uses for the throwout bearings being mentioned after doing some search for information on lubrication for this. Seems a lot of guys out...
Forum:
Forced Induction
05-14-2019, 05:10 PM
33
The Stock Engine Thread
10,020
Posted By
tomm.brz
depeding how hard you drive it, and how good the...
depeding how hard you drive it, and how good the tune is, you could benefit from a bigger coolant radiator too
Once you drive it really hard, oil, coolant, charge temp and Egt can go really high
Forum:
AUSTRALIA
05-09-2019, 01:27 PM
44
JO2 RECALL - ENGINE FAILURE
13,024
Posted By
EAGLE5
Meh. Stock twins have had the same issues as...
Meh. Stock twins have had the same issues as post recall cars. The factory isn't magical. As for a Z, get a used one. Much cheaper and the same car.
Forum:
01-19-2019, 10:48 AM
53
OS Giken Super Lock LSD Install
19,033
Posted By
bhmax
It’s been written elsewhere here, but a lot of us...
It’s been written elsewhere here, but a lot of us including myself have left out the bushings (of the total Whiteline setup) closest to the head of the vertical diff bolts. It surprisingly removed a...
Forum:
01-18-2019, 05:53 PM
53
19,033
Posted By
justinco
I did not. So keep in mind my install...
I did not.
So keep in mind my install might not apply to absolutely everyone. If it seems out of wack, you should probably go through the full process to be sure.
My OS Giken contact (who...
Forum:
Forced Induction
12-14-2018, 08:34 PM
1,372
394,731
Posted By
Trefoil
I went to a Jackson Racing dual radiator cooler...
I went to a Jackson Racing dual radiator cooler and experience extremely solid values from IAT sensor, OTS, and CTS. It has been a functional upgrade for driving in both cold and heat in a high...
Forum:
12-11-2018, 08:23 PM
1
Square cut or angle cut exhaust tips...Is there a difference?
782
Posted By
soundman98
it's a purely aesthetic/design choice. the...
it's a purely aesthetic/design choice. the overall pipe sizing, header style, midpipe style, and muffler is going to affect the sound.
Forum:
Forced Induction
12-09-2018, 12:47 PM
1,372
394,731
Posted By
Irace86.2.0
For daily spirited driving and canyon carving you...
For daily spirited driving and canyon carving you will be fine. All I have is an OEM oil cooler/regulator. An upgrade to a better oil cooleris commonly recommended for more aggressive driving, but I...
Forum:
Software Tuning
08-01-2018, 10:13 PM
51
Calibrating my Stg1 tune after 4-1 EL header install
16,610
Posted By
vtekdis
I see that now in the section 1.2 STARTER LOAD...
I see that now in the section 1.2 STARTER LOAD LIMITS. Thanks for the help freerunner! I'll report later when the tune is loaded and it's got some miles on it.
Forum:
DIY (Do-It-Yourself) Guides
06-19-2018, 07:36 PM
31
Octane Booster Mix Advice?
18,078
Posted By
BellaItalia
non-E
...and now to muddy the water (and you can collectively yell at me, DON'T DO IT, WHAT A MAROON)...what do you think is the difference (in burning/ignition at the plug) between 87 E10 vs. 87 non-E ? ...
Forum:
Software Tuning
06-06-2018, 04:24 PM
10
OFT. Error midway of writing back original tune. Now engine wont' crank.
2,766
Posted By
steve99
Very small loads like cameras are ok. It stuff...
Very small loads like cameras are ok. It stuff like audio power amps window motors that draw high current or are transient loads
Forum:
Software Tuning
07-25-2017, 09:25 PM
110
Replacing a Bricked damaged or faulty ECU with new or used ECU FRS BRZ GT 86
73,073
Posted By
steve99
AFAIK the ecu hardware is same for all ecu...
AFAIK the ecu hardware is same for all ecu 2012-2016 regardless if auto/manual or which country. I have not tested every combination but done a few now no problems.
The ECU will always accept...
Forum:
Software Tuning
04-12-2017, 11:28 PM
118
EcuTek How the system Works
55,173
Posted By
steve99
Ecutek Cable kit Tunes licensing explained
Ecutek Tuning system consists of several components
Basic ProECU Kit Retail - (OBD cable and DESKEY, mst people refer to DESKEY as a dongle, note...
Forum:
03-29-2017, 10:54 AM
295
DIY - Transmission / Diff Fluid Change Reference Guide
399,746
Posted By
2point0
I can't say for certain that the LS oil will be...
I can't say for certain that the LS oil will be BAD for the trans, but it's more expensive and there's no point in wasting it there. If you're uncertain, just use the regular Gear300 for both trans...
Forum:
03-26-2017, 04:16 PM
295
399,746
Posted By
Exrald
It's because the oil had to warm up a bit. After...
It's because the oil had to warm up a bit. After 2-3 minutes, it gets pretty smooth. Once fully warmed up, it's hella smooth. It's worth it!
2013 SCION FRS (Argento)
Instagram: theunforgottenfrs
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
04:44 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
