Old 09-03-2021, 07:39 PM   #1
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Verus CF driveshafts.
Simple question.
Need an honest review of the Verus CF driveshaft by those that have one installed with regard to Install difficulties, increase, if any, in NVH, and overall satisfaction with the unit.
Also for those using one with the IRP shifter. Have you had any issues with rubbing with both fitted.
Apparently there is a post here somewhere from someone mentioning the issue.
Thanks in advance.
Bodalenko is offline   Reply With Quote
Old 09-03-2021, 07:43 PM   #2
StraightOuttaCanadaEh
Wes
With any aftermarket driveshaft, diff and subframe bushings cause a change in pinion angle and vibration at around 80 mph. Stock cars don't seem to have this issue.
Instagram: @gt86ws
Old 09-06-2021, 03:37 PM   #3
gpvecchi
gpvecchi's Avatar
I have the STi bushings (4 on the subframe and 2 in the back of the differential), same shape of stock ones.
Do you think I would suffer of vibrations from the driveshaft?
gpvecchi is offline   Reply With Quote
Old 09-06-2021, 04:52 PM   #4
billstock67
Drives: 2017 Toyota 86
Originally Posted by Bodalenko View Post
Simple question.
Thanks in advance.
I had 2 that vibrated above 80 mph. I do have Whiteline differential, subframe, and transmission crossmember inserts, which may have influenced things.
billstock67 is offline   Reply With Quote
Old 09-06-2021, 05:24 PM   #5
Wes
Don't think so. I think it's the bushing inserts that do it. Not sure if replacement bushings do it.
Instagram: @gt86ws
Old 09-07-2021, 11:48 AM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Simple question.
Thanks in advance.
In this case, you just had to scroll
Old 09-07-2021, 09:10 PM   #7
Grady
Grady's Avatar
I would look for the original design one. I have Whiteline transmission, subframe and diff inserts along with Torque solutions engine mounts. It is possibly causing a harmonic noise above 130 MPH. Can’t say I am worried about it I don’t get there at any of the tracks around here.
Half priced CF driveshafts? Impureclient Engine, Exhaust, Transmission 3 08-28-2018 09:06 PM
DSS vs PST Carbon Driveshafts chazmuska Engine, Exhaust, Transmission 9 07-05-2018 08:57 AM
PST vs DSS carbon driveshafts, anyone compare? OICU812 Engine, Exhaust, Transmission 26 06-15-2014 03:10 PM
Where are the aluminum driveshafts? post_break Engine, Exhaust, Transmission 22 04-01-2013 05:31 PM
AT Carbon Fiber Driveshafts RallySport Direct Transmission and Driveline 33 12-15-2012 12:35 AM
