Old 06-08-2018, 01:44 PM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Exclamation OS Giken Super Lock LSD Install
If you were ever wondering what it takes to install a OS Giken differential, here you go This isn't so much a howto but a general guide to be used as a reference. Not a terribly difficult job but if helps to be familiar with how your car comes apart.
[ame]http://www.youtube.com/watch?v=YQbHA6zT59Y[/ame]
justinco is offline   Reply With Quote
The Following 14 Users Say Thank You to justinco For This Useful Post:
bhmax (12-20-2018), churchx (06-08-2018), cjd (06-08-2018), Code Monkey (06-08-2018), CSG Mike (06-08-2018), Erick KY (06-08-2018), gtengr (06-09-2018), JMon85 (06-11-2018), Joesurf79 (06-08-2018), Joveen (12-11-2018), new2subaru (01-20-2019), rns294 (06-11-2018), Sportsguy83 (12-20-2018), Teseo (06-09-2018)
Old 06-08-2018, 02:19 PM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I saw this yesterday and asked the discord what exacrtly is better about this.vs the OEM? Just stronger and lighter?
Breadman is offline   Reply With Quote
Old 06-08-2018, 02:22 PM   #3
Erick KY
Drives: Raven FR-S 6MT
You didn’t mention any gasket when you were putting the cover back on. Omission? Or is it not necessary there after?
Erick KY is offline   Reply With Quote
Old 06-08-2018, 02:32 PM   #4
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I show the gasket going on in the video. It is the gasket from DIF/FRsport.
https://frsport.com/dif-10590-differ...asket-fr-s-brz
Now that you mention it, I think I forgot to add that to the video description.
Old 06-08-2018, 02:36 PM   #5
an OEM Torsen LSD becomes open when one wheel loses traction or is lifted off of the ground.
The OS Giken, or similar clutch type LSD, can physically lock the rear wheels together, so that you have to either lose traction with both wheels, or you don't lose traction at all, in the rear.
This can have many effects, but the biggest ones are that it makes the rear more predictable, since it behaves the same every time, regardless of condition, and can stabilize the car further under braking (or destabilize the rear, if you choose to set the diff up that way, e.g. for drifting).
For cars set up for grip, side effects include being able to recover spins/slides from much greater angles, and making the rear much more difficult to kick out under grip circumstances. In a car set up for drift, the LSD makes the rear end sustain rotation predictably, instead of randomly hooking one tire up and causing a push.
The Following 15 Users Say Thank You to CSG Mike For This Useful Post:
Capt Spaulding (06-13-2018), Iceman (06-10-2018), jcw99 (01-04-2022), justinco (06-08-2018), RavioliG (01-22-2020), RFB (06-08-2018), RJasonKlein (06-08-2018), rns294 (06-11-2018), Rybot (03-14-2019), sid94 (06-08-2018), Sportsguy83 (12-20-2018), Teseo (06-09-2018), TofuJoe (12-20-2018), wparsons (01-18-2019), x808drifter (06-08-2018)
Old 06-08-2018, 02:42 PM   #6
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
You can @ me on discord, or I will never see it.
I would go read this to start: http://osgiken.net/c-1280300-limited...-lock-lsd.html
Old 06-08-2018, 02:55 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
CSG Mike: what should be kept in mind regarding maintenance / long mileage daily driving usage with such clutch type lsd-s? And do they last long?
Old 06-08-2018, 04:35 PM   #8
It varies by the setting of the LSD and the application. I wouldn't be able to give you a blanket answer.
OS Giken LSDs are meant to last the life of the car.
Old 06-08-2018, 04:39 PM   #9
RFB
RFB's Avatar
Drives: FRS
AND - the clunking and associated weird noises with parking lot turns etc., that are very disconcerting for passengers thinking the car is breakin up -lol
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
jcw99 (01-04-2022)
Old 06-08-2018, 04:41 PM   #10
There is no clunking, popping, or unusual noises with an OS Giken LSD that is properly tuned for the car.
I run an ATS LSD on my car, and most people never realize I am running a clutch type diff when they sit in it.
Using an off-the-shelf LSD is like using an off-the-shelf tune. It's probably better than nothing, but the LSD is definitely not a one-size-fits-all. Having one configured to match your car/needs will yield significantly better results.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
jcw99 (01-04-2022), RavioliG (01-22-2020), wparsons (01-18-2019)
Old 06-08-2018, 04:47 PM   #11
RFB
RFB's Avatar
Drives: FRS
Nice to know those 2 diffs have no scrubbing, clunking etc. associated to lockers.
Old 06-08-2018, 04:51 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
@CSG Mike, I wanted one, but my shop talked me out of it saying overkill for my weekend toy since I no longer track. Would a dialed in OS Giken LSD be beneficial on a weekend canyon carver? Sure sounds better.
Old 06-08-2018, 04:52 PM   #13
They both can. It's really dependent on the tune/setting of the diff.
Likewise, this also applies to Cusco, Tomei, Kaaz, etc.
jcw99 (01-04-2022), wparsons (01-18-2019)
Old 06-08-2018, 04:53 PM   #14
Beneficial? absolutely. Worth it? Hard to say. It's subjective on the worth it end.
I would personally get a LSD before coilovers.
Tokay444 (12-20-2018)
lsd, os giken
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 01:20 PM
Project Mu Lugs BNIB - Racing Floating Nut & Super Lock Nut 7 SonnyBRZ Canada Classifieds 0 02-05-2014 10:37 PM
Results: OS Giken SoPac Super Regional Autox Championship ... des Tracking / Autocross / HPDE / Drifting 5 06-25-2013 11:02 PM
Nagisa Auto D-Lock Super Low Seat Rail poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 3 11-06-2012 04:35 PM
