Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 20 of 20
Search took 0.00 seconds.
Search: Posts Made By: Maritime Storm
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 08-11-2016, 02:32 PM
Posted By Maritime Storm
Thanks, I'm pretty much convinced, for me, this...
Thanks, I'm pretty much convinced, for me, this way to go.
Forum: Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 01-08-2016, 07:47 AM
How often have you seen threads on here about oil...
How often have you seen threads on here about oil consumption? Dealer serviced vehicles are getting Mobil put in them. Mine has only had TGMO(Mobil) in it since new and has yet to consume a drop of...
Forum: Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 01-04-2016, 03:47 PM
Toyota Super Longlife Coolant C0009-00120(Pink)...
Toyota Super Longlife Coolant C0009-00120(Pink) is not the same product as the FR-S Super Longlife Blue C0009-00122. The Super Longlife Blue is the same coolant Subaru uses.
Forum: Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11-30-2015, 05:14 PM
Silicone Spray the door seals will prevent the...
Silicone Spray the door seals will prevent the door freezing to them. I had the belt mouldings and seal replaced under the TSB mentioned last year, immediate end to the window freezing issue.
Forum: CANADA 11-08-2015, 08:21 PM
FYI the RS 1.0 side skirts are $2400 & $2800 ea...
FYI the RS 1.0 side skirts are $2400 & $2800 ea retail through Toyota. We had the misfortune/luck of having to order both sides for one we sold this past summer. The bodyshop I sold them to thought i...
Forum: Scion FR-S / Toyota 86 GT86 General Forum 09-19-2015, 09:12 AM
I can't understand this, the car calls for 91...
I can't understand this, the car calls for 91 octane or higher, it cost 10c/L more and gets upwards of 40MPG. Quit whining about spending the extra $2 on a fill-up, you knew about this when you...
Forum: CANADA 04-20-2015, 06:41 AM
Some have flashed for the idle dip issue, I...
Some have flashed for the idle dip issue, I haven't seen us do one yet. Mine does the idle dip once in a blue moon, and I've never bothered to bring it in for it.
Forum: Suspension | Chassis | Brakes -- Sponsored by 949 Racing 02-26-2015, 07:23 PM
Not according to the parts catalog, same part...
Not according to the parts catalog, same part numbers for front & rear springs, 2013, 14 & 15.
Forum: CANADA 02-26-2015, 07:09 PM
I can say we've only managed to get ours stuck...
I can say we've only managed to get ours stuck once this winter. Wife came out to find they hadn't plowed her parking lot at work last night. Considering the 300+ cms of snow we've received in the...
Forum: Scion FR-S / Toyota 86 GT86 General Forum 08-10-2014, 09:15 AM
We spend too much time on the things we wish we...
We spend too much time on the things we wish we had, instead of focusing on the great thing we have. We have a light, nimble 200hp car that will hold a weeks worth of groceries or a road trip in the...
Forum: Scion FR-S / Toyota 86 GT86 General Forum 08-10-2014, 09:06 AM
I don't buy garage queens, and Henry didn't mass...
I don't buy garage queens, and Henry didn't mass produce the car for it to sit on a trailer. Of course mine will get driven this winter, real bad weather it can stay home and we'll just drive the...
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 07-05-2014, 02:38 PM
Umm That's a Dodge Challenger.
Forum: Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 06-26-2014, 09:08 AM
According to the parts lookup, as of yesterday,...
According to the parts lookup, as of yesterday, Toyota has now stopped carrying the the SU003-00311 filter and replaced it with the 90915-YZZS1 with no stock showing on the Toyo Roki one in North...
Forum: Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 05-24-2014, 07:27 AM
You could try asking politely.
Forum: Scion FR-S / Toyota 86 GT86 General Forum 05-21-2014, 06:50 AM
HUMFRZ; Sums it up nicely. If Momma ain't happy,...
HUMFRZ; Sums it up nicely. If Momma ain't happy, ain't nobody happy. Worse than that, if Momma ain't happy, I get stuck in the passenger seat real quick.
Forum: Scion FR-S / Toyota 86 GT86 General Forum 05-19-2014, 07:44 AM
For a smooth ride at 100+ KPH, I'll tolerate...
For a smooth ride at 100+ KPH, I'll tolerate looking at the weights.
Forum: Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 05-18-2014, 07:49 AM
This is a common issue old timers have with the...
This is a common issue old timers have with the newer engines. They can't understand the use of such thins oils(for instance Honda is switching to 0W16 this year), what most are failing to note is...
Forum: Scion FR-S / Toyota 86 GT86 General Forum 05-02-2014, 07:10 AM
I ran the part numbers at work yesterday for any...
I ran the part numbers at work yesterday for any Canadians who care. Most of those numbers were stocked at both the Vancouver & Toronto depots. The TRD Quickshifter is showing Discontinued in our...
Forum: CANADA 04-24-2014, 06:14 AM
Actually the Mobil engineer I spoke with tells me...
Actually the Mobil engineer I spoke with tells me it is. The TGMO 0W20 is Mobil's Advanced Fuel Economy to be technical, the conventional oils are Mobil Super. Transmission fluids are unique to...
Forum: CANADA 04-22-2014, 07:04 AM
Check your local Toyota dealer. We sell TGMO 0W20...
Check your local Toyota dealer. We sell TGMO 0W20 for $5.70/L at my parts department at Acadia Toyota in Moncton, NB.
