go_a_way1, MisterSheep
Old 05-15-2018, 11:55 AM   #18901
Ashikabi
Ashikabi's Avatar
Originally Posted by JustSomeGuy View Post
what about the people who wrap brand new wide body kits? wouldnt that be the same?
Maybe they spray them with clear first.
The vinyl stuck to the bumper but not anywhere near like it did to paint. Maybe it is good enough but it wasn't worth the risk to me to have to redo it
Old 05-16-2018, 11:18 AM   #18902
Azyael
Drives: Toyota 86
I guess in this case I'll buy a new fender, primer and clear coat it myself before wrapping.
Azyael is offline   Reply With Quote
Old 05-16-2018, 12:38 PM   #18903
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
Originally Posted by pcguru2000 View Post
https://www.ft86club.com/forums/show...9&postcount=29
Custom center mount license plate mounting instructions with parts list. For $32. License plate top is about 1" above bottom bumper.
Do you have more pictures of the end result? A few shots with it on the car would be helpful.
I've been looking to do something similar
02.ACCORD.DUDE is offline   Reply With Quote
Old 05-16-2018, 12:55 PM   #18904
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
get this from 3M, itll do the trick for your new parts
https://www.3m.com/3M/en_US/company-...3194218&rt=rud
JustSomeGuy is offline   Reply With Quote
The Following User Says Thank You to JustSomeGuy For This Useful Post:
Azyael (05-16-2018)
Old 05-17-2018, 03:13 PM   #18905
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Installed Grimmspeed relocation bracket.
Small fitment issue with 17 86's. There is a detachable plastic trim that sits underneath the rod that screws into the tow hook, which required small trimming before I could refit the piece to the bumper.
They drilled holes twice, and used one. Something you would only see once the bracket was removed. The grill appears to be replaceable as it has it's own part number. That is the next thing on the list.
Old 05-17-2018, 03:39 PM   #18906
johan
Drives: '14 981CS, '99 NB1
They drilled holes twice, and used one. Something you would only see once the bracket was removed. The holes are quite large, I will have to look around for a plug large enough to cover that.
Just replace the grill, they're not that expensive.
https://parts.olathetoyota.com/oem-p...le-su00301532/
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
RToyo86 (05-17-2018)
Old 05-17-2018, 05:23 PM   #18907
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Added a tow hook for, like, towin' stuff.
Thanks to @GT LXXXVI for the great deal!
MJones_RB is offline   Reply With Quote
Old 05-17-2018, 05:47 PM   #18908
mrg666
pessimistic skeptic
mrg666's Avatar
I am wondering if there is a reason for relocating the license plate off center other than aesthetic preference?
Old 05-17-2018, 05:53 PM   #18909
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
yes, increases air flow 72%
Leonardo (05-18-2018), spike021 (05-17-2018)
Old 05-17-2018, 05:57 PM   #18910
spike021
spike021's Avatar
For me it's the idea that I can remove it and 'restore' the front bumper whenever I want (take the relocator piece off and re-insert the cover piece).
I like having the choice and the idea there isn't any permanent damage being done to the car.
Also, because fake racecar.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 05-17-2018, 06:13 PM   #18911
new2subaru
Weight Weenie
Drives: 15 FR-S
I relocated mine to the trunk. It looks great back there.
(It'll be back on soon)
The Following User Says Thank You to new2subaru For This Useful Post:
MJones_RB (05-17-2018)
Old 05-17-2018, 06:24 PM   #18912
mrg666
pessimistic skeptic
mrg666's Avatar
Oh,i didn't know race cars had off-center license plates. I might have an obsessive-compulsive disorder but I will keep it centered. Everything must be centered and all numbers must be even
Nah, I am just too lazy to deal with license plate. I am looking for a spring face-lift for my car and looking for something that will overcome my laziness barrier. Valenti taillights, I guess.
Old 05-17-2018, 06:46 PM   #18913
RToyo86
RToyo86's Avatar
Alternative to drilling holes in the bumper is the main thing for most people I would think.
My plate was also mounted low and blocking the venting to the radiator. I doubt it makes a huge impact, but it would be something for Mythbusters.
Old 05-17-2018, 06:50 PM   #18914
Riiiiiiiiiiight ..........
The Following 3 Users Say Thank You to humfrz For This Useful Post:
RToyo86 (05-17-2018), Sapphireho (05-17-2018), spike021 (05-17-2018)
