Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-17-2014, 05:11 AM | #1 |
Oil and water cooling
So, lets discuss about oil and water temperate issue.
Your 1) Cooling modification 2) City cruising water/oil temperature 3) Track water/oil temperature Here is main: 1) FBM shroud with Spal fans, Koyo radiator, FBM oil cooler, additional hood and bumper ventilation 2) 205F/217F 3) 219F/246F Last edited by Boba_kz; 07-18-2014 at 01:35 PM. |
07-17-2014, 04:02 PM | #2 |
Drives: 2014 BRZ
Stock BRZ engine and exhaust
1) Perrin oil cooler 2) City Water: 190F Oil: 190F 3) Track Water: 212F Oil: 235F Ambient: 90F Sent from my iPhone using Tapatalk
The Following 2 Users Say Thank You to Sleepless For This Useful Post: | Boba_kz (07-18-2014), kombatlion (07-17-2014) |
07-17-2014, 04:48 PM | #3 |
in orbe terrum non visi
Drives: violent
Mine is the same as sleepless
8 quart oil pan, amsoil dominator, cowl rubber seal removed, plastic removed from cowl area of hood.
The Following User Says Thank You to Reaper For This Useful Post: | Boba_kz (07-18-2014) |
07-17-2014, 07:11 PM | #4 |
Turning is for Nerds
Drives: 35 characters is not enough
1. Perrin Oil Cooler
2. City: Water 190 F, Oil 170 F (winter) 190 F (Summer) 3. Track (65 F ambient): Water 212 F, Oil 214 F Bonus track data from the same day from a BRZ with no cooling mods running the same data collection utility and running the same pace: Water 212, Oil 276 |
The Following User Says Thank You to Decay107 For This Useful Post: | Boba_kz (07-18-2014) |
07-17-2014, 07:41 PM | #5 |
1. None
2. 195f/205f 3. Didn't log water / 290f oil
2013 Lightning Red - 6MT Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler |
The Following User Says Thank You to brn12345 For This Useful Post: | Boba_kz (07-18-2014) |
07-17-2014, 10:27 PM | #6 |
Drives: 2012 Toyota 86
cusco oil cooler
city 190 water, 200 oil track 212 water, 230-250 oil. |
The Following User Says Thank You to troek For This Useful Post: | Boba_kz (07-18-2014) |
06-18-2017, 04:20 PM | #7 |
Drives: GT86 Harrop S/C
06-18-2017, 06:27 PM | #8 | |
Drives: GT86
0) NA - Factory tune
1) Cusco Oil Cooler 2) - No data - 3) 201 F / 255 F (Converted from C) 15min session Bonus: I managed to get the temps up to 208 F / 266 F on a 30 minute session. Quote:
While I don't have hard facts we do have a really looooong right-hand sweeper on one of our tracks which normally causes issues with oiling. I've had no issues. |
The Following User Says Thank You to lazyluka For This Useful Post: | Bfranklyn86 (06-19-2017) |
06-18-2017, 08:38 PM | #10 |
Huge E85 fan!
Drives: 2016 Scion FRS
NA with tune
removed the rubber seals around hood grill delete My drive to work is mostly highway and the oil temp would always get hot ont he highway- I have seen it get up to 220 F cruising on a hot doing 80 MPH. But once I did the grill delete I was surprised to see my oil temps consistently 5-10F cooler. It hasn't gotten over 210 yet and that was normal before. I don't really get it and I wasn't expecting it. My IAT is down a few degrees and I expected that but the oil temp thing was a surprise. |
06-19-2017, 03:10 AM | #11 | |
The Following User Says Thank You to Bfranklyn86 For This Useful Post: | lazyluka (06-19-2017) |
06-19-2017, 11:29 AM | #12 |
Drives: 2017 Series Yellow BRZ
So correct me if I am wrong, I was under the impression oil temps below 212F are not a good thing because you are not vaporizing water that is coming in through fuel system?
I see some above that are below that threshold. Ideally I thought oil temperatures should be in the 230-260 range??? |
06-19-2017, 05:12 PM | #13 | |
08-08-2017, 03:58 AM | #14 |
Similar Threads | ||||
Brake cooling | Model Citizen | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 115 | 08-28-2018 11:28 PM |
BRZ Fog delete for air duct/cooling | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 01-31-2014 12:46 PM |
Cusco Supecharger kit with water cooling | Thongpocket | Forced Induction | 1 | 09-23-2013 12:54 PM |
brakes and cooling | DRACHENV6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-11-2013 10:34 AM |
TF Brake Duct Cooling Kit | Touge Factory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 02-19-2013 06:04 PM |
