11-06-2021, 10:47 AM | #43 | |
Sent from my SM-G781B using Tapatalk |
11-06-2021, 11:33 AM | #44 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
OP is using the FA20 cylinder heads anyways, so FA20 headers will almost guaranteed work. Will they be optimized? Probably not.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
The Following User Says Thank You to Goingnowherefast For This Useful Post: | sato (11-09-2021) |
11-06-2021, 11:56 AM | #45 | |
The Following User Says Thank You to Brz-123 For This Useful Post: | Goingnowherefast (11-06-2021) |
11-07-2021, 10:17 AM | #46 |
ProCrastinationConsultant
The Following User Says Thank You to soundman98 For This Useful Post: | sato (11-09-2021) |
11-07-2021, 12:48 PM | #47 |
Drives: '13 BRZ TLM Spec
Per the documentation, it's in the same location.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
11-07-2021, 02:03 PM | #48 |
Dismember
Drives: 2013 Red Scion FR-S
Redline is 6000k. Normally turbocharged. Designed for torque. Lower compression. It's interesting, but is it really going to have more power if not turboed?
11-07-2021, 02:15 PM | #49 | |
Drives: Crapcan
This is the 22’ BRZ short block he bought. Not the turbo Acent/Crosstrek engine.
The Following 7 Users Say Thank You to NoHaveMSG For This Useful Post: | BrahmaBull1990 (11-08-2021), EAGLE5 (11-07-2021), Goingnowherefast (11-07-2021), kevaughan (01-07-2022), Opie (11-08-2021), PulsarBeeerz (11-07-2021), soundman98 (11-07-2021) |
11-07-2021, 03:21 PM | #50 |
Drives: 2013 frs red
The fa20 heads seemed to flow more than needed so maybe they'll be dead nuts for the larger displacement?
11-07-2021, 04:32 PM | #51 |
Drives: 2020 BRZ Sport Tech RS
Excited to see how this build goes!
Is the plan to machine the heads to match the larger bore, or...?
11-07-2021, 04:41 PM | #52 |
I'll let OP comment but that's usually not needed. No one does it on the really popular K20/K24 hybrid. It's a good example, because it's 2.0L heads with a overbored 2.4L crankcase.
The Following 2 Users Say Thank You to Goingnowherefast For This Useful Post: | BrahmaBull1990 (11-08-2021), soundman98 (11-07-2021) |
11-07-2021, 05:44 PM | #53 | |
That would mean a substantial amount of extra material sitting around the top of the bore, which at the very least would be sub-optimal for combustion, if not downright problematic. This is closer in concept to an EJ20 / EJ25 combo - I haven't really looked into what they do with those, but I'd be surprised if the heads are untouched with a 7.5mm increase in bore. EDIT: I looked into the EJ20 / EJ25 combo, and to do it properly, it seems they either machine the heads to enlarge the combustion chambers or use custom pistons to bring the compression ratio back down. Otherwise C/R is too high. That said, some folks DO run it without either... EDIT 2: Running some quick rough numbers, the combustion chamber volume for an FA24 is 19.47% larger than the FA20's, so with the FA20's combustion chamber volume unmodified that would make the hybrid's C/R about 13.74:1. That is a BIG jump that would be hard to tune for. The stepped shape at the top of the bore would also make for some funky swirl of the mixture as it compresses, and could create some major heat risers that would trigger detonation. With all that considered, I don't think it would be a great idea to run it without machining the heads to match...
The Following User Says Thank You to Tatsu333 For This Useful Post: | alphasaur (11-07-2021) |
11-07-2021, 06:34 PM | #54 |
Drives: Q5 + BRZ + M796
Machining the head seems necessary. The pistons could cause interference with the lip of the head, and if the lip of the heads are sharp then they could be a location for preignition, or at best, they could cause weird tumbling of air coming into the cylinder. Personally, I feel like getting the heads machined was already a given.
11-07-2021, 07:07 PM | #55 | |
11-07-2021, 08:49 PM | #56 | |
The FA20/24D has domed pistons to create the high compression. Here are some pictures of my blown engine. The piston height is visible from the side, and the piston in the background shows a piston close to TDC with a dome shape and impedance reliefs in the crown for valves. I’m sure if someone wants to throw some low compression pistons in there then there is no risk of any issues. If Toyobaru changed the valve angle or valve opening height to make it open higher or enlarged the valves then that could cause interference, depending on the tolerances. Regardless, the edge of the cylinder-head combustion-chamber probably will interfere with the crown of the piston without machining.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Tatsu333 (11-08-2021) |
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
