11-05-2021, 04:44 PM | #29 | |
Drives: Q5 + BRZ + M796
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post: |
11-05-2021, 05:29 PM | #30 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
The Following User Says Thank You to Goingnowherefast For This Useful Post: | Lantanafrs2 (11-07-2021) |
11-05-2021, 05:40 PM | #31 |
friendly
Drives: 17' 86
A bargain compared to alternatives.
Seek comfort in discomfort.
The Following User Says Thank You to alphasaur For This Useful Post: | soundman98 (11-07-2021) |
11-05-2021, 06:12 PM | #32 |
So it’s basically the same price as the FA20 short block. I got FA20 short block through a friend at a dealer for around 1800. I suspect the FA24 could be had for similar discounts if you know the right person.
The Following 3 Users Say Thank You to ermax For This Useful Post: |
11-05-2021, 06:53 PM | #33 |
Drives: 2015 FR-S
Curious about @Opie plan for the heads to get compression back to 12.5 The FA20 heads will actually introduce a quench/squish area when paired with bigger bore of FA24 (which I guess can be desirable for velocity and mixturing). Probably also need a head CC kit to get compressed volume even across all 4 heads if material is taken out.
The Following User Says Thank You to FrickingReallySlow For This Useful Post: | Opie (11-05-2021) |
11-05-2021, 07:25 PM | #34 |
Meow
Drives: GT86, Volvo 996
Surprisingly so. Probably looking at three grand once you account for the ancillaries. Then what else do you need?
-Header, if you're still stock? -Tune? Which might become available off-the-shelf in the not-too-distant future If that works out, it might yield 250 OEM-like hp for the price of a decent supercharger. N/A, with a "new" engine, higher reliability and less weight. Speaking of which, interested in seeing the weight penalty between FA24 & FA20 short blocks. Probably less than an FI kit anyway. |
11-05-2021, 07:45 PM | #35 |
11-05-2021, 08:26 PM | #36 | |
Drives: '13 BRZ TLM Spec
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following User Says Thank You to Opie For This Useful Post: | BrahmaBull1990 (11-06-2021) |
11-05-2021, 08:55 PM | #37 | |
Sent from my ONEPLUS A5010 using Tapatalk |
The Following 3 Users Say Thank You to Ashikabi For This Useful Post: |
11-06-2021, 04:40 AM | #38 |
Drives: '15 BRZ RA
Is it not the FA24 short-block longer? Hope you don't have clearance issues.
11-06-2021, 10:01 AM | #39 |
No. It should be the exact same size externally.
11-06-2021, 10:15 AM | #40 |
The Following 4 Users Say Thank You to Brz-123 For This Useful Post: |
11-06-2021, 10:18 AM | #41 |
The question here is will it use the same CPS (crank position sensor). That's another critical sensor you'll need to determine engine position. If it is different, it may be possible to swap the gen 1 sensor in.
11-06-2021, 10:35 AM | #42 |
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
