#281 |
Drives: 86 GT
I had this noise with the stg2 e85 OFT tune. Now with the 4-1 EL catless header and matching overpipe i just installed, i cant hear the noise anymore. running the stock exhaust from the overpipe back so my car is not loud at all.
something to do with the acoustics in the factory header? im no expert on this. |
The Following User Says Thank You to uncivilised For This Useful Post: | keen as (04-08-2014) |
#282 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#283 |
Drives: 86 GT
EL header.
#284 |
Drives: 86
i got EL header
made the sound worse !!!! |
#285 |
Drives: 86 GT
which header do you have? i have the mx performance 4-1 EL header from sydney
#286 |
Drives: 86
nameless performance
#287 |
Drives: FT86
When you installed headers you probably ran the stage 2 tune for el headers? This tune runs more timing advance and that probaably made yourknock worse. If you did not change tune catless headers will generally make you run a bit leaner again possibly increasing knock as the tune for headers also adds fuel . In Oz run 100 octane RON or pull some timing or both for low rpm high load knock
#288 | |
Drives: 86
yeah as you said I ran the stage 2 EL tune however, i was using that same tune before the nameless header was installed also, i have been using e85 before header and after the mettallic sound makes me cry |
#289 |
Drives: FT86
QUOTE=Pistol;1668785]yeah as you said I ran the stage 2 EL tune however, i was using that same tune before the nameless header was installed also, i have been using e85 before header and after the mettallic sound makes me cry[/QUOTE] Gees knock on E85, can you see it in the logs as knock correction or drop in kc learned ?, if no sign of knock in logs then it might be something physicaly loose or hitting on exhaust, heat shields? |
#290 |
Drives: White MT FR-S
#291 |
Drives: Scion FR-S/Toyota Yaris
The problem with this on is you would have to drive x number of miles with an aggressive vvt tune, pull the cams and mic them. Nobodies going to do that. I can say going from A00C to B01C calibration eliminated the noise under load at 5k rpm. I was convinced the noise was just a resonance but the drastic difference in factory tunes has changed my mind.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#293 |
Interesting change here: I've been running the OFT / OTS Stage 2 EL 91-93 oct tune for about 2 months (prototype catless EL header; 93 Octane all the time). The timing/valve/knock noise was very pronounced at 4K +/- rpm, and the motor seemed more "noisy" overall than when I was running the basic Stage 1 OTS tune.
I just loaded the OTS Stage 2 EL E85 tune (1.59 bin) and ran the car for the first time this morning. The 4K mechanical noises do not seem to be present and the engine "seems" more quiet and smoother overall. I doubt that the fuel system is entirely purged of the 93 octane gas just yet, and have only run the car about 4 miles / 20 minutes since the new tune. But my experience seems to be somewhat the reverse of what's being expressed in this thread . . .? Is this just the result of the difference in the E85 vs 91/93 octane tunes? Admittedly, I have not researched this particular difference or really followed the threads. |
#294 | |
Drives: WR Blue BRZ, 240Z
Maybe @shiv@vishnu can respond when he returns from his honeymoon.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Variable Valve "Butterfly" Exhaust | dlux | Southern California | 19 | 02-22-2016 06:21 PM |
First tank OFT E85 tuning. Noise? | Tromatic | Software Tuning | 2 | 02-20-2014 05:43 PM |
Exhaust Cut Off Valve | beagoodruslan | Engine, Exhaust, Transmission | 2 | 01-01-2014 01:47 AM |
Exhaust Noise that goes away after warmed up | FastLane1000 | Engine, Exhaust, Transmission | 10 | 08-15-2013 10:06 PM |
Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
