Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-15-2013, 11:56 AM | #1 |
Drives: White FR-S, 6M
Exhaust Noise that goes away after warmed up
Guys, I've posted in the overpipe threads but I'm not sure thats my issue. I did have to adjust things to clear the hotckis sway bar but I've taken care of that. I have an exhaust noise which I would describe as rasp. I hear it when the car is not up to full operating temperature. The exhaust needs to be heat soaked before its gone but it does go away so that tells me its not the overpipe hitting. I have the FA20club header and was wondering about the Vband. The noise is under full throttle at 5K RPM or higher. Anyone else notice this sound and found a resolution? Exhaust is FA20Club EL header catted and coated, Motiv overpipe coated, and Motiv Front pipe catted. Rear is stock. Thanks for your input.
08-15-2013, 11:59 AM | #2 | |
I Love custom Turbo kits
Drives: Limited BRZ
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | Nightbringer (08-16-2013), wparsons (08-15-2013) |
08-15-2013, 12:03 PM | #3 |
Thanks, but its doing something it shouldn't. must be a leak somewhere. Motor is fully warmed but exhaust has just cooled off a little.
08-15-2013, 12:04 PM | #4 |
Drives: 85 corolla gts
If there is a leak you should be able to find it at idle. When cold spray with soapy water at your connections before you start it. Then see if you get any bubbles (this is the safer way). I typically will place my hands around all connections making it a point to try and not actually touch any thing to see if I feel any air coming out (the not so safe way). I would also recommend letting your vehicle get up to proper operating temperature before you drive aggressively. Hope this helps.
The Following 2 Users Say Thank You to Ross For This Useful Post: | Nightbringer (08-16-2013), Sportsguy83 (08-15-2013) |
08-15-2013, 12:09 PM | #5 | |
Sportsguy83 said it though. Don't go over 5k when the engine isn't warm. Your engine internals DO hate you for it.
08-15-2013, 12:21 PM | #6 |
Betting its the noise of the aggressive cold start vibration in the header, which explains why it goes away when it is warm. There's a million videos of how awful this sound is on un-resonated exhausts with headers that quiet down after warmup.
Don't drive any car hard until it is warm, unless you want to replace it in 50k miles. |
08-15-2013, 12:26 PM | #7 |
I have a header back exhaust that has a lot of rasp on startup. After about 1 minute of driving and letting the engine warm up, it's completely gone. It's just the pipes being cold.
08-15-2013, 12:31 PM | #8 |
I appreciate the input regarding a solution but I really don't drive the car hard before the motor is warmed. I was trying to explain that the exhaust needs to be heat soaked before the sound is gone. This happens long after the motor is fully warmed. Sounds like the consensus is its header related. Thanks!
08-15-2013, 09:38 PM | #9 | |
It's easily 5x as loud at a cold startup than once warm, even 100% stock.
The Following 2 Users Say Thank You to wparsons For This Useful Post: | husker741 (08-15-2013), Nightbringer (08-16-2013) |
08-15-2013, 09:43 PM | #10 |
Aftermarket headers are thinner and the heat plate on the stock header acts as a muffle too.
08-15-2013, 10:06 PM | #11 |
You're very right and I totally forgot to mention this. Thanks for the input.
Similar Threads | ||||
Exhaust Noise Levels | EN2_Squirrel | Engine, Exhaust, Transmission | 0 | 07-11-2013 10:32 PM |
Road/Exhaust noise mitigation? | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 03-05-2013 06:55 PM |
What's this noise? | Nitesh31 | Issues | Warranty | Recalls / TSB | 3 | 12-19-2012 09:35 PM |
HID noise | Carlsbad | BRZ First-Gen (2012+) -- General Topics | 6 | 06-20-2012 12:39 AM |
