Old 01-13-2016, 07:17 AM   #1
kaede1337
Drives: Silver '13 FRS
aftermarket wheels, lug nuts torque spec
I just got some wedssports sa-10r with kics caliber 24 lug nuts and the instructions say to torque them to 88-118Nm (65-87 ft lbs). Should I use the factory 89 ft lbs or the kics recommended maximum 87 ft lbs?
kaede1337 is offline   Reply With Quote
Old 01-13-2016, 10:22 AM   #2
-Phil
Drives: Rb25 neo brz
Kics makes most of their lugs out of forged steel so use their recommended TQ spec
-Phil is offline   Reply With Quote
Old 01-13-2016, 05:22 PM   #3
tyler_win_photo
tyler_win_photo's Avatar
A 2 ft-lbs difference shouldn't make much of a difference. Your torque wrench probably has more error than that.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
chaoskaze (01-13-2016)
Old 01-13-2016, 09:57 PM   #4
15limited
15limited's Avatar
I've got weds TC105N's with Kics R26 and I've take them off, put them on and torque'd them to 89lbs a dozen times in the past couple months, no problems yet.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 01-13-2016, 10:53 PM   #5
kaede1337
cool thx guys, any one know if the tmps will work on these wheels?
Old 01-13-2016, 11:19 PM   #6
kaede1337
Old 01-14-2016, 08:02 AM   #7
15limited
15limited's Avatar
I read a couple posts on here somewhere mentioning tpms are a tight fit for the TC105N, but I had the factory sensors installed and haven't had any problems yet.
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Torque spec for lug nuts wrxneffect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 09-06-2016 08:39 PM
Help with lug nuts for aftermarket wheels TooFRSh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-10-2015 11:53 AM
OEM lug nuts with aftermarket wheels? srtblake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-18-2014 03:48 PM
Factory wheels with aftermarket lug nuts. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-21-2012 08:40 PM
