Drives: 2013 Red BRZ Limited
OFT multiple cars
Can you load and OFT tune on two similar cars with the same mod's?
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Edit: if you want to flash more cars go with ecu tek and buy 2 licenses |
Thanks, just curious.
Drives: SWP BRZ
maybe we pay another amount less device such as license fee to OFT and make it possible?
Seems reasonable to me after all once you've loaded your tune how often do you need it
Sent from my SM-G900V using Tapatalk
#6 | |
It to do with the way the hardware works The OFT is a powergate 3 programmer from alientech. The device marries to single car unless you flash back stock tune. some features can be changed by the oft guys, but the marrying part is not changeable. |
Do OFT users keep the tablet hooked up all the time?
If so how is it mounted? Sent from my SM-G900V using Tapatalk
#8 | |
You can however use OFT as a extra guage display for monitoring stuff like oil temp knock coolant temps and a whole heap of other stuff. you can also set alarms on these parameters to sound if say oil temp exceeds a certian amount of knock etc. you can also use the oft to do the "pedal dance" to completly disable traction and stability control (more than buttons on console) mounting ides here http://www.ft86club.com/forums/showthread.php?t=52212 http://www.ft86club.com/forums/showthread.php?t=78665 http://www.ft86club.com/forums/showthread.php?t=88464 see also link below OFT Tips and Tricks . |
#9 | |
| Multiple oil leaks. | samisons | Issues | Warranty | Recalls / TSB | 13 | 02-02-2017 03:13 PM |
| WTB: Multiple Items | BRZach | Want-To-Buy Requests | 2 | 12-31-2015 11:04 AM |
| Multiple Fuses Blown? Uh oh. | KelvinBRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-21-2014 12:43 AM |
| Playing with big horsepower cars at 86Fest II... (now with multiple views!) 8/19/13 | CSG Mike | Tracking / Autocross / HPDE / Drifting | 20 | 08-20-2013 11:29 AM |
| Multiple allotments for 2012? | bloomy116 | BRZ First-Gen (2012+) — General Topics | 5 | 04-15-2012 01:20 PM |
