Old 01-06-2016, 03:02 AM   #1
Vincent Nguyen
Drives: black queen
Talking Questions about TRD springs and 17x9 wheels
Hi all, this is my first post and I am a new member since I bought my FRS few weeks ago.
My car is a pre-owned, it is lower on TRD spring, has a sway bar and front end links. I am thinking about getting Enkei RPF1 17x9. So my questions are:
1. Would I be able to fit that wheel size? (I am getting wheels first meanwhile saving up for a really good set of coilovers)
2. What extras parts should I buy to get custom wheel alignment? And what would be a good alignment spec for that set up?
3. What is a good choice of tires for that set up?
It is really tough for me to buy wheels and coilovers at once. That's why I am thinking about buying wheels first since the tires are almost out. I would love to have a set up that can handle spirited driving and track.I am sorry for asking too many questions, any response will be appreciated. Thank you!
Vincent Nguyen is offline   Reply With Quote
Old 01-06-2016, 07:46 AM   #2
ollie
ollie's Avatar
Drives: GT86
Have a look over this, it will give you most of the info you are after http://www.ft86club.com/forums/showthread.php?t=7535
ollie is offline   Reply With Quote
Old 01-06-2016, 10:15 PM   #3
tyler_win_photo
tyler_win_photo's Avatar
1) You should be able to fit that wheel. Might be a little tight on clearance between tire and spring perch, but should clear.
2) If your goal is get a custom wheel alignment, I'd suggest lower control arms for the rear and camber bolts for the front.
As for alignment, I'd suggest max out your camber bolts (most negative) and for the rear around -1 to -1.5 degrees depending on how much you drive on the freeway. If you drive on the freeway a lot, you'd want the camber closer to -1.
As for toe, a little negative in the front will give you quicker turn in, but too much negative toe will make the car twitchy at speed. In the rear, you can go for 0 to a little positive. Positive toe will make the car more stable in a straight line.
3) What are you looking for in your tires? Dry grip, long lasting, cheap, etc.
tyler_win_photo is offline   Reply With Quote
Old 01-07-2016, 01:33 AM   #4
Vincent Nguyen
Drives: black queen
thanks ollie for the response
The Following User Says Thank You to Vincent Nguyen For This Useful Post:
ollie (01-07-2016)
Old 01-07-2016, 01:38 AM   #5
Vincent Nguyen
Drives: black queen
3. I am looking for dry grip tires but last at least 2-3 years. I would spend up to $180/tire
2. How much toe for front and rear should I have without destroying tires quickly and be stable at slow and high speed?
Off topic: How do I click thank for a response? can't find any thank button.
Old 01-07-2016, 03:24 AM   #6
swarb
You need +35 offset for a spring setup. +45 won't fit without coilovers.
2-3 years? I suggest looking at tread wear ratings of 300+. I like the hankook v12 or continental dw. Lots of people like michelin pilot super sport.
Toe-in makes tire wear faster and also makes it more stable. It is a trade off.
Most recommend 0 toe or slight toe in the front and slight toe in in the rear or close to zero. How much is slight? Everyone is different, start near stock and go towards zero.
You get the thanks button at 10 posts.
Read more and figure out what is right for you.
Old 01-07-2016, 04:15 AM   #7
Vincent Nguyen
Drives: black queen
Thanks swarb, you guys are super helpful. I'm still a noob, need to learn a lot more.
ollie (01-07-2016)
Old 02-27-2016, 05:44 PM   #8
slow15frs
slow15frs's Avatar
Drives: 15 scion frs
Size:  105.8 KBim running trd springs with 17x9 42 and 2554017 not rubbing even at full lock
Sent from my SM-G928V using Tapatalk
2015 Scion FR-S-hot lava 6MT Perrin cai magnaflow cbe EFI LOGICS tuned 193whp
slow15frs is offline   Reply With Quote
Old 02-27-2016, 07:21 PM   #9
Bykov
Drives: 2014 Monogram FR-S Whiteout
I just saw that image in another thread, those wheels... they aren't TS9's are they? How tight is the fitment? And how do you like the ride with the TRD springs?
Bykov is offline   Reply With Quote
Old 02-27-2016, 07:34 PM   #10
slow15frs
slow15frs's Avatar
No they are rota titans i have about 2.5 mm. The ride is great and handles good only wish was slightly lower but its growing on me with the wheels
The Following User Says Thank You to slow15frs For This Useful Post:
Bykov (02-27-2016)
Questions on trd lowering springs Nictheguy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-23-2015 06:02 PM
Gramlight 57dr 17x9.0 questions ikeryder13 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-08-2014 05:25 PM
Several questions on wheels CyberAkuma Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-18-2014 10:51 PM
Questions about new wheels Sprocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-26-2014 03:50 PM
Lowering Springs Questions Chase86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 08-14-2013 10:19 AM
