Drives: Scion FR-S
Smoke coming from only 1 exit on dual exhaust?
Hey guys, so recently I noticed that smoke is coming from only the passenger side exit of the exhaust but not the driver side. I have a Invidia Catless Front Pipe+Greddy Evo3 Catback...The airflow seems to be a little stronger on the passenger side but the driver side literally emits zero smoke...what could be the issue here?
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Tcoat (01-04-2016) |
Drives: Scion FR-S
Hail Magnet
If the OP has smoke coming out of his exhaust, that might be more a cause than gas exit bias.
However, which side it comes out of more is going to depend more on the angles that the pipes are welded in. Since the exhaust is going to follow the path of least resistance, unless the piping is welded in a perfect "Y" you are going to see more exhaust come out one side than the other. Keep in mind that the dual exhaust in this car is functional, but mostly cosmetic. We only really need a single exhaust, but people generally prefer the look of a dual. |
Drives: 2014 BRZ SCCA STU endurance car
Perfectly normal, most every split exhaust I've installed tends to favor a side.
#6 | |
Not a troll
But again, just to reiterate, very normal. Just looks odd. |
Drives: 2015 CWP BRZ Limited
Doesn't it mean we have a new pope?
| The Following 10 Users Say Thank You to jawn For This Useful Post: | FRSBRZGT86FAN (01-04-2016), go_a_way1 (01-04-2016), humfrz (01-04-2016), HunterGreene (01-04-2016), JoeC (01-04-2016), JoeHK (01-07-2016), kch (01-04-2016), Lord09 (01-04-2016), soulreapersteve (01-04-2016), Tcoat (01-04-2016) |
I suggest you place a rag over the exhaust pipe that most of the exhaust is coming out and see if the exhaust will go out the other side.
Maybe someone jammed a potato up the driver’s side..... ?? …..have you been messing around with someone else’s wife lately …. ?? ![]() humfrz |
#10 |
Drives: Scion FR-S
sounds like the general consensus is that it is not a big deal.
so I tried blocking the side where smoke was coming out from and smoke started to come out on the other side. Once I unblock it, it just goes back to the way it was (passenger side with smoke and driver side with what seems to me just air) |
| The Following User Says Thank You to illest For This Useful Post: | humfrz (01-04-2016) |
| Dezod Dual Exit Cat Back Exhaust - Review | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 16 | 02-07-2016 11:29 PM |
| For Trade: Nameless Perfermance BRZ/Scion FR-S Dual Exit 2.5" Axleback Exhaust | gonzo | Engine, Exhaust, Bolt-Ons | 3 | 07-19-2014 11:54 AM |
| Berk dual exit exhaust | Vlady | Engine, Exhaust, Transmission | 4 | 11-10-2013 10:24 PM |
| White smoke coming from the exhaust. | hansthegerman | Engine, Exhaust, Transmission | 17 | 10-02-2013 04:23 PM |
| Smoke coming from the Exhaust | peachsnow | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 12-09-2012 02:59 AM |
