Old 01-04-2016, 02:46 AM   #1
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Shark Fin Question
So I told my girlfriend that I wanted a shark fin for my car for Christmas. I was joking. I just didn't know what else to tell her since I couldn't really think of anything I wanted.
Anyway, she ended up phoning around a couple Subaru dealerships (and other electronics places) to try to get an idea of how much they cost, etc.
I was just planning on getting a BeatSonic one that I researched some years back but never got around to ordering. But the dealership said they had one but it required rewiring, etc. and it was quite expensive.
Anybody know if the dealership one is worth it, or should I go with the BeatSonic? Not really sure of the benefits/drawbacks of either.
Thanks so much for anybody who can provide me some information or point me to a thread that does. I did a quick search but couldn't find anything specific to my question.
Thanks!
Enemies is offline   Reply With Quote
Old 01-04-2016, 03:14 AM   #2
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Sounds like the dealer is making it sound more complicated than it actually is. Here's a DIY for the OEM Sharkfin antenna:
http://www.ft86club.com/forums/showthread.php?t=76922
Of note though is that there is no Whiteout/SWP version for the OEM Sharkfin. If you're dead set on getting the OEM Sharkfin, you will have to repaint it or find someone to repaint it for you, unless you're fine with a color-mismatched antenna.
The Following User Says Thank You to KR-S For This Useful Post:
Summerwolf (01-04-2016)
Old 01-04-2016, 07:56 AM   #3
Ashikabi
Ashikabi's Avatar
So, on a slightly related topic... has anyone made an antenna delete? I don't use mine and I think they look out of place
Old 01-04-2016, 08:04 AM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Someone posted a carbon fiber plate, but that looked even more out of place. The only way to do it correctly is a filler panel, welding, and body filler / paint.
The beat sonic is what I have. It looks much better than factory and is simply one screw that has to attach. I will say this, your normal radio reception will suffer drastically. I use Pandora mostly anymore.
Old 01-04-2016, 09:38 AM   #5
Ashikabi
Ashikabi's Avatar
In 2 years I've never used my radio. Pandora, yes, but that's thru my phone. I was kinda hoping there would be a little plate(less out of place than that guys carbon fiber one) that would attach somehow. Welding is probably the only way to go though
Old 01-06-2016, 02:19 AM   #6
Enemies
Thanks for the info guys.
I don't really use the radio much but I do once in a blue moon when I have a passenger and feel like putting something on that isn't whatever's on my SD Card or whatever CD is in my car.
So, a bit of a bummer on that front.
Does it have a negative impact on the Navigation at all or is that completely unrelated? If it's just the Radio, it's not the biggest deal.
I've got a Canadian BRZ, and it's White. Paint-matching, etc. seems probably a bit more than what I would want to do. Any pros/cons to getting the OEM one?
Thanks again!
Old 01-06-2016, 09:15 AM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Does not hurt your navigation. I would get the beat sonic again. Paint matched out of the box and ready to install. For the stock one there are how-to's on the board, but it is slightly more involved. Plus being a 2015+ item, it may not match your paint exactly.
Old 01-06-2016, 07:49 PM   #8
B$
86
Drives: Monogram Whiteout
I have the beatsonic 2 sharkfin and my radio/navi is fine.
B$ is offline   Reply With Quote
Old 01-08-2016, 12:11 PM   #9
Enemies
Perfect. Thanks guys.
Looks like the newest Beatsonic is probably the way I will go. Appreciate all the info!
Old 01-08-2016, 12:35 PM   #10
Chanpion
Drives: 13 FRS Satin
I've been trying to find a solution for this, not so much luck yet. The closest I've found is a recent plate on top but it looks terrible.
The other only OEM solutions that may possibly work are the OEM antennas for VW Jettas and for the previous gen Corolla.
http://i.ebayimg.com/00/s/MTIwMFgxNj...TApKH/$_35.JPG
What the Corolla antenna looks like, it doesn't have the light though is is usually painted or just matte black plastic. But it's much smaller than the original antenna we have and possibly not visible from far away.
I was thinking of testing it soon, the only problems I see are a bit of soldering, no problem, if it's actually compatible,which it should be, it's just FM radio and to see if it's actually big enough to cover over the hole where the wiring comes out of. Don't want leaks.
Chanpion is offline   Reply With Quote
Old 01-08-2016, 12:58 PM   #11
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
We made a antenna delete for @nyrip then we wrapped his roof so it didnt look noticeable
Instagram: trevor.parque
Old 01-08-2016, 01:00 PM   #12
Ashikabi
Ashikabi's Avatar
What did it look like prewrap?
Old 01-08-2016, 01:01 PM   #13
MisterSheep
Killed Scion
Litterally just took off the antenna and cut up a rockstar can and place the aluminum from the can in there and then wrapped the roof.
Old 01-08-2016, 01:05 PM   #14
Ashikabi
Ashikabi's Avatar
Oh... I think something a little more professional looking. Especially since I'm not gonna wrap my roof
:popcorn:, did not read
FS- SWP Beatsonic V2 Shark Fin Cards2323 Exterior Parts (Aero, Lighting, Etc.) 4 11-20-2015 11:31 PM
TRD Shark Fin Still Available? Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 6 04-16-2015 10:55 AM
STi Shark Fin Antenna Beyer Subaru Electronics | Audio | NAV | Infotainment 43 10-20-2014 08:52 AM
Need help painting my shark fin Vincenttam Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-10-2014 09:31 PM
Antanna Shark Fin?? scionfr_s Cosmetic Modification (Interior/Exterior/Lighting) 1 02-20-2013 11:29 PM
