Old 12-30-2015, 01:03 PM   #1
shellslinger
Drives: Whiteout FRS
Brake Pad Retaining Clips
Any one know where I can get some for the front brakes?
Currently having issues with my front brakes chirping above 40mph. The chirping noise from the front brakes appears to get louder as I go over bumps but stops once brakes are applied. I recently changed my brake pads to Winmax W2 and I've been getting this chirping noise on the front driver side tire. I then decided to change out the rotors as well. That did not work and the chirp was still there.
Cut it short, last night I put back the stock brake pads and make sure the dust shield was not rubbing against anything. Went for a drive and chirp was still there. I came to the conclusion that my retaining clip may be holding the brake pads loosely causing them bounce up and down when I go over bumps which in turn makes the chirping noise.
shellslinger is offline   Reply With Quote
Old 12-30-2015, 01:42 PM   #2
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Dealer will be your best bet, little parts like that typically aren't too expensive.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
shellslinger (12-30-2015)
DIY: Retaining AND/OR Replacing OEM BT Mic with Aftermarket Headunit ecko04 DIY (Do-It-Yourself) Guides 16 03-07-2019 04:20 PM
Should I have some plastic retaining screws here or something? jeffsquared Issues | Warranty | Recalls / TSB 6 05-23-2014 05:15 PM
Retaining Factory BT Mic w/ Aftermarket Radio ecko04 Electronics | Audio | NAV | Infotainment 4 04-08-2014 06:22 PM
rain guards? clips or no clips? kylem1853 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-29-2013 01:59 PM
Retaining driving dynamic with upgraded tires? - frs nixeighty6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 12-22-2011 01:44 AM
