Drives: 2013 FRS
OFT - Intake adjustments
So, I'm extremely new to software tuning and I'm curious about how the stage 1 OFT 93 oct tune works with modified intakes. I haven't bought an entire new intake, but I've swapped out the filter and added a new, wider silicon intake tube.
Do I have to adjust anything? |
so long as you haven't changed the intake before the MAF sensor (filter doesn't count), you don't need to adjust anything.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
Drives: 2014 GT86
"new, wider silicon intake tube" sounds like he might have changed, thus maf rescaling in tune is good thing to do.
I'm thinking he means something like Perrin's silicone inlet tube, which would not need a MAF adjustment.
Drives: FR-S Whiteout
From my testing, those intake elbow don't do shit with or without tune besides clean up the engine bay and heat soak faster than the stock tube.
"Theoretically" they should be doing something positive for the intake charge, but in practice not so much. If it does it's miniscule and the positive effect is offsetted by the negative faster heat soak effect from my experience.
Intent > Content
cowardice is the mother of cruelty. |
#6 | |
Intent > Content
| DIY camber adjustments? | canadaRS1.0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-28-2015 07:08 PM |
| Cam timing adjustments without dyno | StormTrooper | Software Tuning | 17 | 02-19-2014 04:16 PM |
| Pedal adjustments | supramkivtt2jz | DIY (Do-It-Yourself) Guides | 3 | 03-31-2013 05:56 AM |
| Valve Train Adjustments | @Art_Mighty | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 09-24-2012 09:10 PM |
| Pedal Adjustments? | djliquidsteele | Engine, Exhaust, Transmission | 3 | 06-09-2012 10:43 AM |
