Old 12-28-2015, 05:44 PM   #1
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Great tips on oil temps, pressure, and weights for the track
Great tips on oil temps, pressure, and weights for the track.
[ame="https://www.youtube.com/watch?v=cDfFJ5s6IDg"]FRS - BRZ Oil Pressure and Temperature Tech FA20 - YouTube[/ame]
I'll definitely be switching to a heavier oil once winter is over and track season starts again.
stockysnail is offline   Reply With Quote
Old 12-29-2015, 05:19 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
I track 5w30 on stock drivetrain with oil cooler. He is saying 10w40 would be better?
I don't have a pressure gauge
Old 01-08-2016, 10:59 AM   #3
ChrisD
ChrisD's Avatar
Drives: GT86
Interesting, thanks for posting. I'm in the UK so we don't have extreme heat and usually we don't have extreme cold either, so my engine builder recommended going for 5w30. At the moment (well, since I got the turbo installed a few months ago) I've been running 0w30 but my engine builder says it never really gets cold enough here to warrant having a 0w grade oil.
I was surprised in the video that he said if you've got a turbo you'd need to go straight to 10w40, as the shop that installed the turbo specifically recommended 0w30 to me (and I believe that's what they use in their 420 bhp turbo track only GT86, but I'll ask them).
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 01-08-2016, 01:47 PM   #4
Jawnathin
Drives: Toyobaru FRZ
I don't track my 86 but 0W-30 sounds too thin for a track car. It's sheer strength would be non-existent once up to temp and its gonna cook a bearing. A heavier oil will maintain viscosity and offer better protection at higher temps which you would certainly see on track and even more with a turbo.
If I was gonna track my 86 I'd probably run 10W-40. That is what I run on my Z06 with oil temps at top off about 270F.
Jawnathin is offline   Reply With Quote
Old 01-08-2016, 02:24 PM   #5
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
5w-30 for me with an oil cooler, temperature stabilizes at around 230, pressure stays above 55psi, stays stable for 1+ hour lapping sessions.
I'd be real hesitant going to a 40 wt unless the car lives it's life at the track. Just going to rob power and efficiency in a street car.
Decay107 is offline   Reply With Quote
Old 01-25-2016, 06:17 PM   #6
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Oil http://www.ft86club.com/forums/showthread.php?t=91820
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
tire pressure sensors needed on track only wheels? snuff58 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-02-2015 01:48 PM
Worried about 1st track day oil temps cookiesowns Tracking / Autocross / HPDE / Drifting 74 07-13-2015 12:00 PM
BRZ vs. Fiesta ST - great track review Sport-Tech FR-S / BRZ vs.... 34 02-07-2014 04:25 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
BEST TIRE PRESSURE TO RUN TRACK karma003 Tracking / Autocross / HPDE / Drifting 13 10-24-2012 05:32 PM
