Old 12-28-2015, 11:04 AM   #1
brzest
Drives: '15 BRZ
Coilover options Bilstein/KW/Öhlins/RCE/Tein
Hi,
If I lived in the US, my options would be simpler, but the price differences are quite big on some products (eur/usd rate isn't helping either) Based on the prices that I would get the parts for, what would be your choice?
My car is a daily driver, but I'd like to do atleast 6-8 trackdays a year and am willing to compromise on the street rather than track, I guess. Winter and salt are very present so that's an issue as well, allthough I suppose I could swap to OE setup for the winter.
My first choice would be Öhlins R&T MI20, but it seems to be out of stock everywhere in Europe and seems to be replaced with the MP20 kit, which is without camberplates and strange spring rates. If ANYONE has a line on a set of the 'old' MI20's in Europe, please let me know!
So my current options are (I realise they price/quality difference is quite wide on these...)
These are the coilovers I can get from Europe locally (seems to be quite a big price difference when looking at US prices)
Bilstein B16
around €1,500 / $1,650
KW V3
€1,700 / $1,870
KW Clubsport 2-way
€1,800 / $1.980
Öhlins Road & Track MP20 (without camber plates 4kg/mm front and 3kg/mm rear springs)
€2,200 / $2,420
Now two kits that could be ordered from the US, that I can't get from Europe:
Öhlins Road & Track MI20 with camber plates and 6kg/mm F&R about
about €3,700 shipped and customs/VAT paid / $4,070
RCE Tarmac 2's without camber plates
about €2,900 / $3,200 shipped and duty paid,
about €3,500 / $3,850 with camber plates
And from Japan, I could get:
Tein SRC's for around €3,500 / $3,850 with customs duty and VAT paid
Based on those what would you suggest? I'm a beginner with everything that has to do with suspension, so I probably won't be very good at setting up the suspension (thus, afraid of the 2 way adjustable options somewhat...) I should mention that I'd like to stay under €3,000, so the Öhlins from the US and Tein from Japan would be difficult, probably would have to be postponed by one year...
brzest is offline   Reply With Quote
Old 12-28-2015, 11:11 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Well if I were you I would scratch the Bilstein's off your list as they are a progressive spring rate. I am sure they would be great for street use but if you want more performance at the track go with one of the other options.
Old 12-28-2015, 11:56 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I sometimes wonder as to why Ohlins decided to discontinue MI20 with firmer rates when on most forums those are advised and more commonly wished for over MP20 kit. What happened with demand driving offer/voting with wallet? :/
Old 12-28-2015, 12:06 PM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
Haha...
I just went through the same thoughts. You might want to read the answers to my questions:
http://www.ft86club.com/forums/showthread.php?t=98951
Tor is offline   Reply With Quote
Old 12-28-2015, 01:34 PM   #5
Racecomp Engineering
What kind and what size tires do you plan on using for track days?
- Andrew
Old 12-28-2015, 01:55 PM   #6
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
I think kW club sport or tein SRC? Ohlins RT is good for DD and track but not focus on track and their clubsport is about more than 6k? I think.
BTW, why clubsport in Europe is soooo cheap....
ZHoward is offline   Reply With Quote
Old 12-29-2015, 02:20 AM   #7
brzest
Drives: '15 BRZ
- Andrew
Stock size Advan AD08.
After that thinking about gettng 17x8 wheels, so will likely go with 225 AD08R's or similar.
Tell me about it... If the MI20's were available in Europe for a decent price, I'd just buy those and call it a day! I could live without the camber plates on the MP20's but those spring rates just seem wierd... Maybe they work somehow by some miracle? Would love to find out, if anyone has them on allready...
Originally Posted by Tor
Haha...
Thanks, just read through the thread and subscribed. Not sure the ST's are for me since over here we do get alot of snow and salt in the winter. Allthough I guess I could always remove the coils for winter. Interested to see how it works out for you, though! Maybe I'll change my mind
Old 12-29-2015, 11:43 AM   #8
Tor
Tor's Avatar
Drives: Toyota GT86
My thinking is that dampers need replacing or rebuilding anyway. With a price of 1000€ (compared to 2600 for Clubsports), I can replace them more often.
That said, the winters are not that hard in northern Germany and I have a second old car to drive when there is salt and snow on the roads. For you stainless steel might make more sense.
Old 12-29-2015, 01:06 PM   #9
I think KW V3 or KW Clubsports would treat you well.
Over here the Clubsports don't have a warranty, which is unfortunate. I'm not sure if that's true in Europe. They're slightly firmer spring rates would be nicer on the track, but the V3s still do pretty well. Also, you may not need camber plates depending on how much camber you plan on running since you can get a good amount with the slotted lower mount of the KW's.
The old Ohlins would do well too, but I wouldn't bother with the new ones.
- Andrew
Old 12-29-2015, 02:20 PM   #10
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
You might also look at SACHS Performance coilovers. Much easier to get a set in Europe than the U.S.
They're similar to the B16s in that they're a single-adjustable coilover with an inverted monotube shock up front and progressive rates in the rear. Of course people will say that progressive rates aren't as ideal for tracking a car, but if you're only doing 6-8 track days a year it's definitely more of a daily driver that's occasionally tracked. The progressive rear rates may make for a more comfortable ride while daily driving, and should still handle just fine (especially at your experience level) on track. They're just slightly softer sprung than the new V3 rates, so not a bad compromise for a DD that sees some track time throughout the year.
I'm in pretty much the exact same situation in terms of daily driving and amount of track time in a given year, and ended up with the SACHS coilovers (although working for their parent company and getting a special price did help sway my decision). haha But from an objective standpoint, as I'm not here acting officially on behalf of the company (just an enthusiast who happens to work there), it's a very well respected company that's know for making great products. I'd say it's at least worth looking into.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 12-29-2015, 11:16 PM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Sachs^^
Old 12-30-2015, 08:07 AM   #12
brzest
Drives: '15 BRZ
- Andrew
Thanks! Looks like the European Clubsports are just V3's with different spring rates (6k front, 7k rear, so EU Clubsport = US V3, I belive?)
I would love to get T2's with higher spring rates, but the 20+% customs duties on the price + shipping kind of kill the deal
I have also e-mailed several Öhlins distribitors (including their Nürburgring center) to see if maybe they have one set left collecting dust somewhere, fingers crossed
I will definitely keep an eye on your solution! I saw you also contacted Öhlins, let me know what they tell you regarding the new R&T kit.
They do look nice, from the little I've seen, but they are amazingly hard to find anywhere. Also as someone said before, don't want to be a guinea pig for those, would rather use something proven/tested. Interested to see what you think of them, once installed, though.
Old 12-30-2015, 11:12 AM   #13
The US KW V3s are softer now (they changed them a few years back), so I think US and EU V3s are the same. Good luck!
- Andrew
Old 12-30-2015, 12:24 PM   #14
Shark_Bait88
Originally Posted by brzest View Post
T
There are some other people out there that have them, but not many. There's a SACHS demo car in Japan with a blog covering a lot of what they've done, but I'm having trouble finding the page. It's also all in Japanese, and the translation is not great.
There's also this video, same problem with the translation though.
[ame="https://www.youtube.com/watch?v=XRJLzmwFF-Y"]SACHS RS1 PERFORMANCE COILOVER THE ROADSHOW for 86,and BRZ - YouTube[/ame]
I am very excited to see how they are once I get them on though. My RCE Camber Plates should be waiting for me when I get home today! Now I just need the snow to go away. lol
Opinions: Tein Flex A or RCE Tarmac/Bilstein ChrisSC300 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-06-2015 12:39 AM
Bilstein B14 vs Tein Flex vs ISC N1 vs MCA Blue (Coilovers) xkwizt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-24-2015 05:10 PM
Bilstein B14 Coilover vs KW V1 vs KW V3 Stayreal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-18-2014 09:25 PM
TGS| KW | ST | Cusco | HKS | TEIN | ISC | EIBACH | BILSTEIN | WHITELINE | Suspension TopGearSolutions Brakes, Suspension, Chassis 150 04-14-2014 08:34 PM
>>>Bilstein B16/PSS10 Coilover - US Release<<< FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 12-20-2013 12:47 AM
