Drives: SWP BRZ
OFT stuck beeping in realtime data mode
Hey, everyone.
I updated my OFT to the latest firmware version (v1.34) and now it won't stop beeping and changing the screen brightness while in realtime data mode. Any ideas why this is happening? I've recalibrated the display and tunes flash over just fine. The only issue is the beeping in realtime data mode. Any help is appreciated. Thanks!
#2 | |
make sure your using openflash manager 1.24.0 or the latest one on that page then download and apply the latest Template file , think its 8.2 and you should be good to go |
| The Following User Says Thank You to steve99 For This Useful Post: | PandaBRZ (12-26-2015) |
Drives: Toyota GT86
If the above doesn't work, check the ODB cable, if it's not seated correctly it can do very strange things to the OFT. Even if it looks ok, try to reseat it again.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| The Following User Says Thank You to elBarto For This Useful Post: | PandaBRZ (12-26-2015) |
Drives: SWP BRZ
Just tried but it's still doing it. I'll check the cable next.
Drives: SWP BRZ
Checked the cable as well and both connectors were tight. Maybe the cable went bad? It was working fine before the firmware update... Strange.
#6 | |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | PandaBRZ (12-27-2015) |
#7 | |
Drives: SWP BRZ
Thanks for the fast response, Shiv!
| Beeping after ignition turns off.. | chadstyle | BRZ First-Gen (2012+) — General Topics | 45 | 07-20-2020 01:53 PM |
| Realtime/Live logging | wgr73 | Software Tuning | 4 | 05-13-2015 12:34 PM |
| Beeping noise when shifting | Lmiller40 | Engine, Exhaust, Transmission | 25 | 05-25-2014 02:41 PM |
| car beeping after engine shuts off | mystic | Southern California | 10 | 04-14-2014 05:47 PM |
| [Help] Iphone stuck in Subaru connect mode. | Kiske | Electronics | Audio | NAV | Infotainment | 7 | 09-03-2013 12:24 AM |
