Old 09-01-2013, 09:18 PM   #1
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
[Help] Iphone stuck in Subaru connect mode.
Plugged my phone into the usb so I can listen to it on my morning drive. When I shut the car off however it did not disconnect. I turn the car back on and it the nav screen just says loading/searching.
So I disconnected everything and my iphone doesn't react. Still has the sube logo on it and says "ok to disconnect" no buttons seem to work... Any thoughts on what to do before I hope it fixes itself when the battery dies?
iphone 5
subaru brz limited
Old 09-01-2013, 09:58 PM   #2
mswhong
iphone 5
subaru brz limited
Disconnect battery for 30 seconds, ECU will have to readjust but that should be fine.. other than that take it to your dealer, they should be able to flash/fix the software for you!
mswhong is offline   Reply With Quote
Old 09-02-2013, 11:32 AM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The car is back to normal but my phone still is in subaru mode. I have about 6% battery life left on it so we'll see if that fixes it.
Old 09-02-2013, 11:34 AM   #4
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
For iPhone...should be able to hole power button down (top button) and iPhone will allow to slide to power off....then reboot.
MightyMeeple is offline   Reply With Quote
Old 09-02-2013, 01:38 PM   #5
jonzhuxD
Drives: Ultramarine FR-S
You can press and hold the power button and home button simultaneously until the iPhone restarts. It might take 10-15 seconds of holding but it'll restart. It should be fine afterwards
jonzhuxD is offline   Reply With Quote
Old 09-02-2013, 02:38 PM   #6
RIPTRD71
RIPTRD71's Avatar
Drives: Raven FR-S 6MT
^Correct!
Originally Posted by wootwoot View Post
She's stiff as a goose. I tried yanking out the motor too, that was pretty stiff as well. So.. i'll try the flux capacitor next.
RIPTRD71 is offline   Reply With Quote
Old 09-02-2013, 11:10 PM   #7
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Problem was the buttons werent resonding on the phone while it is in that state.
The battery died. I'll plug it in tomorrow morning and hopefully it is fixed.
Old 09-03-2013, 12:24 AM   #8
jonzhuxD
Yeah when you hold the home and power button nothing will happen on the screen for that 10-15 seconds. The screen will just shut off and the apple logo will appear and your phone will reboot. You can try this even when it's not stuck, it's something built into the hardware, it works in nearly any situation. Saved my ass a few times I needed to make a phone call but my phone was being stupid.
Here it is under resetting your iPhone
http://support.apple.com/kb/ht1430
How to connect this headunit? Amir Ghadiri Electronics | Audio | NAV | Infotainment 8 07-23-2013 11:57 AM
Subaru BRZ, Scion FR-S Stuck With a Software Glitch MarkWF1 Issues | Warranty | Recalls / TSB 10 10-11-2012 09:23 AM
Is it possible to connect subwoofer? Ronin_car_lover Electronics | Audio | NAV | Infotainment 4 08-01-2012 10:10 PM
snow mode = girlfriend mode? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 9 07-01-2012 03:02 PM
Help!! No sound when connect my ipod/iphone with cable percyng Electronics | Audio | NAV | Infotainment 16 06-21-2012 04:20 AM
