| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Drives: 2015 Subaru brz
Air compressor for air tools?
So guys what do u guys recommend for an air compressor for home that is a good enough for air tools or should I just go electric... All I plan doing is basic car stuff with it not trying to open a shop lol.. Lmk ur opinions boys..
Sent from my Nexus 6 using Tapatalk |
Air is always better.
Choose your tools and see what the minimum required PSI is and then buy something that gives you at least 25% more than that. You can always dial back pressure but can't increase it if the unit doesn't have enough.
Do gallons matter
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Yes...always go as big as you can afford and have room to fit...the more the better. Like memory for computers, you want as big a reservoir as possible. And like Tcoat says, make sure the flow rate of the compressor is more than capable for the tools you will be using.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Cool I'm looking at a 30 gallons which are around 150 to 200 and that's has much space as I have as well.. Looked at really like good electric ones and go for 300+... With that I'll buy compressor drill and wrench lol
Member of the year - 2016
Drives: Scion FRS
Air tools are great, but you'll be hard pressed to find any shop now that doesn't have a cordless impact wrench and drill.
not playing cards
Impact wrench is the quickest way to fuck up a fastener. Breaker bar to loosen, torque wrench to finish. If you want fast, use a cordless drill.
Drives: Nevermorange FRS
Yes, I definitely recommend an air compressor for air tools. They work way better that way.
PRO86 | WTCC | STL
Also...even though I have an air compressor and 2 air rachets and die grinder I never use the air tools...always manual or electric. My air compressor is just for airing up the vehicle tires...which it does most excellently...30 gallon would be about the minimum you'd want.
What is basic car stuff that needs a drill? Go corded electric drill for inexpensive yet heavy duty and dependable service. Cordless are okay for light and infrequent use... not the best at extended or heavy duty use.
#10 |
Drives: 2013 Pearl White 6MT
Seriously I only use my air compressor for remodel jobs. Mostly with my brad nailer. Never used on on cars. Easy to strip something out
#11 | |
#12 | |
not playing cards
Gratuitous tools for such infrequent, small-scale work, IMHO. I have a full set: 1/2" impact, 3/8" butterfly, air ratchet, die grinder, blah blah blah. Never use them. Compressor to air up tires but I fine-tune with a bicycle pump.
#13 |
Drives: BRZ + Ducati M796
I have a portible six gallon compressor. I was thinking of having a secondary wall tank as a reserve for when I need it, but I rarely use it. Air tools would be nice in certain situations or would be perfect if I owned a business and was doing volume work, but I dont.
#14 |
Agreed that it's unnecessary for hobby work, the only time it would actually be useful is if you have to disassemble some POS that's seized, and even then most air tools wouldn't be strong enough and you need to cut through it.
All you need are hand tools and a corded electric or two, the cordless stuff batteries die after less than five years in my experience and then it's tough to find replacements, I've used some corded electrics that are older than I am, probably made before Reagan took office. |
| AC compressor tweet | Hanzo | Issues | Warranty | Recalls / TSB | 96 | 07-04-2020 07:19 PM |
| Tools for air compressor ;) | Mikeez | Issues | Warranty | Recalls / TSB | 6 | 11-30-2014 05:14 PM |
| Compressor/pump noise when car is off | Zardoman | Issues | Warranty | Recalls / TSB | 11 | 03-10-2014 05:06 PM |
| Idle dip ONLY with COMPRESSOR on | #87 | Issues | Warranty | Recalls / TSB | 2 | 11-14-2012 11:12 AM |
| A/C Compressor blowing hot? Is this normal? | SocalBurt | Engine, Exhaust, Transmission | 3 | 08-22-2012 07:10 AM |
