Drives: 2016 Scion FRS Release Series 2.0
What Header for Performance
Hey,
I am sort of new to the mod scheme of the BRZ, and I am looking to replace my stock header. So far I have done exhaust and that really it for mods. ANy suggestions on what header to get. What I am looking for in header: - maximum performance/ HP gain/torque increase - sound increase doesn't matter because My current exhaust sounds good enough - reasonable pricing because I am not loaded Thanks for your help |
Drives: 2013 Ultramarine FR-S
Do you prefer EL or UEL?
What's your current exhaust set up? |
Well for my tastes the N1 is too loud with a header but that's all personal tastes and local laws.
EL is equal length runners on the header UEL is unequal length runners on the header. Here is a good place to start. Header & Overpipe compilation thread http://www.ft86club.com/forums/showthread.php?t=81491 |
And another thread for you to read
Basic Bolt on mods intake, exhaust tuning guide http://www.ft86club.com/forums/showthread.php?t=81493 |
ok thank you, UEl or El doesn't matter to me, Just looking for a list of headers that Give significant horse power boost
Drives: Whiteout FRS
The consensus lately is to get the ACE Header. They seem to provide the most hp/tq for the header. However, to maximize these header along with any other header you would need a tune. Appears that the only tune at this time that will maximize the gains of the ACE header is the Ecutek tune.
here is the link to the thread w/ dyno results: http://www.ft86club.com/forums/showthread.php?t=88696 |
#8 | |
Their is not rearly much difference in catless EL/UEL just pick your sound you like UEL gives the boxer rumble. For the street UEL usually give a bit more midrange so its usually better where your using the engine most For arround $700 you can get a good EL/UEL header Tomei Gruppe-S Openflash OFH or similar you will get about 20hp gain with tune Or if you want the best performance probably the ACE header but its arround the $1400 mark maybe 5hp over the others Whatever header you get your going to need a tune, else most of the gain will not be available and you will throw CEL code P0420 you need to look at a header and tune package. Last edited by steve99; 12-24-2015 at 06:40 PM. |
#9 | |
for cheap tune your looking at an Ecutek Flash and Go tune (canned ) tune these are about $600 (Ecutek licience plus tune) IF you have a local ecutek dealer to flash the tune. If you dont your up for another $400 for a cable to flash. Other option is the Openflash Tablet, device to flash tunes that comes with a selection of tunes for EL/UEL 91/93 fuels and E85 fuel. Its $500 and you flash your own tunes whenever you like. They do a Tablet/tune and header package for about $1100 if you want uel header http://openflashtablet.com/Automotiv...OFH/index.html unless you have a quiet catback any catless header is going to be quite loud, if you fit a header be prepared to put your stock catback back on if its too loud, the stock catback is not restrictive, it just does not sound the best but it is quiet. you can then sell your aftermarket catback to recover some money |
#10 | |
Drives: 2013 Asphalt FRS
Videos are on this site in the 1/4 mile time thread or go to youtube type 13 47 frs if you want to hear it also 13 52 frs
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#11 |
with that setup was their a noticeable difference in power when driving
#12 | |
Go drive a new SI civic and that will give you a idea
#13 | |
If you want the best bang for your buck, gut the cat out of your stock header. If you want the best performance, you want an Ace 4-2-1 header. Don't forget to budget for a tune, or you'll only really get a change in sound with a minimal change in power. You need the tune to prevent a CEL, and maximize the gains. |
#14 | |
Drives: White 2014 BRZ
13.5 is damn impressive. Are you on slicks? Very cold weather? I'm in Florida so it is warm even now. Edit: I see you have gears and slicks. That's probably making the difference. Agree? Since I can only do a 2.2x maybe 2.15. Last edited by stevo585; 12-24-2015 at 09:54 PM. |
| Tags |
| brz, header, performance |
| 1320 Performance UEL Header? | Ronin Sascha | Engine, Exhaust, Transmission | 53 | 06-27-2018 06:39 AM |
| Ark performance Grip or DTS with unequal length header? | RogueBRZ | Engine, Exhaust, Transmission | 18 | 06-04-2016 09:24 AM |
| Top Speed Pro-1 Performance Header | golfyankee2121 | Engine, Exhaust, Transmission | 18 | 02-23-2016 11:13 AM |
| FS: Nameless Performance EL header, coated | toeout | Engine, Exhaust, Bolt-Ons | 25 | 05-07-2014 11:03 PM |
| Exhaust/Header/Performance Guidance | eddieEndo | Engine, Exhaust, Transmission | 2 | 09-29-2013 10:48 AM |
