Old 12-23-2015, 07:03 PM   #1
ivangonzal5
Drives: GT-86 White Pearl
OFT for GT86 (Not USDM)
Hello, I'm looking to buy an OFT but:
-I don't have cruise controls in my GT-86 ,
-I also live in Panama, where our 95oct is likely 91oct on US.
Questions:
-If i don't have the cruise controls, will I be able to change LC limits?
-v2.00 Maps says USDM only, Will I be able to flash those maps stating that our fuel is likely 91oct? or is there any other limitation?
-Will I run in any issue? I'm afraid that OFT will not be compatible at all with my vehicle.
ivangonzal5 is offline   Reply With Quote
Old 12-23-2015, 07:21 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Only ecutek changes LC rpm on the fly.
First you need to find out your calibration code, maybe go to a shop that has tactrix or ask around your local clubs to see if you can find someone to pull the rom from your car.
Then go to openflash.com and download the roms and see if one is included for you calibration code, or tell us what it is and we can tell you if it's already included.
If it's included already you're good to go, buy the OFT and flash.
If not you can send the rom to openflash so they can copy the base maps to your calibration code and you'll still be able to use the OFT.
Old 12-24-2015, 12:39 PM   #3
ivangonzal5
Thank you, I will look how to get the calibration code
Old 12-24-2015, 04:39 PM   #4
steve99
ELM327 adapter and android torque application will get calibration, or obd scantools may also be able to see calibration id it will be something like ZA1JA01G
FS Tom's USDM Red Taillights $325 ethn Exterior Parts (Aero, Lighting, Etc.) 18 11-14-2015 05:04 PM
USDM GT86 with AVO Turbo! nataku Member's Car Journals 133 04-02-2015 02:03 PM
Can a GT86 Airbag fit inside USDM Steering wheel? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 3 04-28-2014 08:53 PM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 03:55 PM
