Old 12-23-2015, 02:31 PM   #1
cabusi
cabusi's Avatar
Drives: 2015 FR-S Hot Lava Man-Trans
Do Buddy Club LCA drop car height?
I'm running a set of Buddy Club LCA on my car because I needed the camber adjustment in the rear to fit my tires. I am also running a set of TRD springs on stock shocks until I can afford a set of coilsovers. I noticed that my rear is lower than the front after adding the LCAs. Anyone else running Buddy Club LCA on springs? Here are the bolts I have setup. Maybe I need to switch holes on some of the LCAs. Thanks in advance.
cabusi is offline   Reply With Quote
Old 12-23-2015, 05:12 PM   #2
Cole
Not a troll
Cole's Avatar
Judging by the fact there's 2 mounting holes then, I'd say yes.
The Following User Says Thank You to Cole For This Useful Post:
go_a_way1 (12-23-2015)
Old 12-23-2015, 05:17 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
OEM ones don't have the bend like that, aftermarket ones that do are used to lower the rear, such as yours.
Old 12-26-2015, 02:38 AM   #4
8686
8686's Avatar
Drives: 86
Can you show us a picture of the car from outside.
I want to see how much drop it added to the rear.
Thanks
Sent from my 86 using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 12-28-2015, 06:05 PM   #5
cabusi
cabusi's Avatar
Rear is about a half inch lower than front.
The Following User Says Thank You to cabusi For This Useful Post:
8686 (01-01-2016)
Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc Chase Bays Brakes, Suspension, Chassis 14 02-03-2016 09:14 PM
PBM pro coilovers drop height keonigt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-13-2015 09:27 PM
CA: FS Buddy Club LCA merino_frs Brakes, Suspension, Chassis 1 06-16-2015 10:30 PM
The Buddy Club!!! JamesBond000 Engine, Exhaust, Transmission 23 08-01-2014 09:29 PM
Can i drop my car an inch or more and then raise it back to stock height? ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-01-2012 09:02 PM
