Old 12-18-2015, 06:49 AM   #1
kilohercas
Drives: Subaru BRZ (soon?)
OEM Subaru BRZ connectors
Hello, i am in a process of professionally adapting Lenovo Phab Plus tablet as head-unit.
It will add my own charging, power sequencing, and other electronics to mimic original functionality only by using original tablet functions ( like turn on when car is accessory is turned on, but will not shutdown it by cranking the engine, like original does, basically, will use MCU to track car status, and generate signals for tablet. very simple
My original problem, is that i must use original wiring loom, but i have no idea where i get same connectors ( PCB mounted, not wire), just like in original headunit
So i need mail part that is PCB mounted, any idea about part numbers and/or digikey link ?
And yes, i will be making DIY guide how to properly install tablet to car But first, i need to get connectors
kilohercas is offline   Reply With Quote
Old 12-18-2015, 05:58 PM   #2
P3tras
Drives: Subaru BRZ '13 WRB
I think you will have to cut connectors, my friend Or get old/faulty toyota head-unit just for connectors.
P3tras is offline   Reply With Quote
Old 02-22-2016, 07:12 AM   #3
kilohercas
Originally Posted by P3tras View Post
I think you will have to cut connectors, my friend Or get old/faulty Toyota head-unit just for connectors.
By chance and knowledge it looks like i was able to find USB and signal connectors from digikey, so this is great.
For power and seekers, i will use standard connectors, and buy adapter from ebay or local distributors, it should work just fine
http://www.digikey.com/product-detai...207-ND/2273586
http://www.digikey.com/product-detai...707-ND/4813976
Old 01-28-2018, 02:51 PM   #4
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Originally Posted by kilohercas View Post
A - USB
B - Rear Camera Pre-wire
C - GPS Antenna
D - 10-pin & 6 pin power/speaker harness
E - 28 Pin SWC/aux/mic harness
F - Antenna
G - Sirius/XM antenna
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 01-30-2018, 12:22 PM   #5
Imp
Bring out your dead
Bump ^^^^ Anyone?
--kC
Old 01-30-2018, 03:08 PM   #6
Originally Posted by Imp View Post
Bump ^^^^ Anyone?
--kC
https://demos.starbase7.net/t3Portal...+2016+MY+FR-S+[05%2F2015+-+]&docid=989162&context=ti
Where to get OEM wiring connectors? brianhj Electronics | Audio | NAV | Infotainment 8 02-01-2016 03:50 PM
Subframe connectors? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-24-2014 02:17 PM
OEM Connectors taylork057 Scion FR-S / Toyota 86 GT86 General Forum 2 01-17-2014 01:00 PM
Connectors in trunk retoocs BRZ First-Gen (2012+) — General Topics 4 07-26-2013 03:37 AM
Oem amp connectors cruzinbill Electronics | Audio | NAV | Infotainment 10 01-31-2013 05:47 PM
