Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 12-17-2015, 03:42 PM   #1
Diode Dynamics
Diode Dynamics's Avatar
Arrow Diode Dynamics Subaru BRZ RGBW Multicolor LED DRL Boards! USA Made!
2013-2016 Subaru BRZ RGBW Multicolor LED Boards
From the factory, the 2013-2016 Subaru BRZ has LED panels in the headlight that illuminate for the parking light and DRL. With these Diode Dynamics OEM-grade replacement LED panels, you can upgrade your look by making them function as both the white running light, with full multicolor functionality.
Made in USA: These DRL Boards were proudly CAD-designed by our engineers right here in St. Louis, Missouri to be an OEM-grade, drop-in replacement for your factory DRLs! These use high quality LED emitters that ensure extremely high brightness, even during the day. The RGBW 5050 LEDs are high-binned for color uniformity.
This product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
There is a standard RGBW input plug (5-pin) to connect to your RGBW controller, which should then be powered by your parking lights or any other 12V signal. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty.
For OEM-grade reliability, the LEDs are protected by a thermal management system, which is integrated into the panel and driver. If the temperature of the LEDs becomes too high for any reason, the output of the LEDs will decrease, to ensure long life in even the harshest environments. And of course, the advanced constant-current driver ensures that there will be no damage to the LEDs long-term from the harsh electrical system of the vehicle.
Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels. Checkout our dealer locator tool:
Find a Diode Dynamics Dealer
All Diode Dynamics products are backed by a 3-year replacement warranty.
[ame]http://www.youtube.com/watch?v=ifmj2ktqr54[/ame]
Diode Dynamics: 2013-2016 Subaru BRZ Multicolor LED Boards
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
IG: ProjectBRZ
Old 12-17-2015, 03:48 PM   #2
Diode Dynamics
John C.
Diode Dynamics
Old 12-18-2015, 09:17 AM   #3
Diode Dynamics
John C.
Diode Dynamics
Old 12-28-2015, 12:04 PM   #4
Diode Dynamics
John C.
Diode Dynamics
Old 01-05-2016, 09:42 AM   #5
Diode Dynamics
John C.
Diode Dynamics
Old 01-10-2016, 09:17 AM   #6
Beechnut87
Drives: White 2015 Series Blue BRZ SC
Any issue with the glue when baking the headlights? I did a ROBO mod on my 3000GT and dealing with the glue was a pain and required the factory glue to be removed and new windshield adhesive to be installed to replace it and make things easier. Looks much easier in the video but that glue was a real PITA until i had a friend use a heat gun as i scraped glue out with a screwdriver!!
Beechnut87 is offline   Reply With Quote
Old 01-11-2016, 03:14 PM   #7
Diode Dynamics
The BRZ uses rubber butyl to seal the housings. It's easy to work with, and shouldn't require too much effort to separate.
If you aren't confident in your ability to remove the lenses, we have a great network of authorized dealers: http://www.diodedynamics.com/store/i.../find-dealers/
Feel free to give us a call if you have any questions: (314) 205-3033
Thank you!
Nick C.
John C.
Diode Dynamics
Old 04-20-2016, 10:04 AM   #8
Diode Dynamics
John C.
Diode Dynamics
Old 04-28-2016, 10:09 AM   #9
Diode Dynamics
John C.
Diode Dynamics
Old 04-28-2016, 11:19 AM   #10
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
This would be awesome if there was a kit for the DRLS on a BRZ as well. Both controlled at the same time.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 04-28-2016, 04:42 PM   #11
Diode Dynamics
The BRZ's lower DRLs are much more difficult to open up. They aren't sealed the same way the headlight housings are.
Nick C.
John C.
Diode Dynamics
Old 05-03-2016, 10:09 AM   #12
Diode Dynamics
John C.
Diode Dynamics
Old 08-04-2016, 11:10 AM   #13
Diode Dynamics
John C.
Diode Dynamics
Old 08-10-2016, 11:25 AM   #14
Diode Dynamics
Demon Eyes are small, high-power LEDs that illuminate the projector lens inside your headlight, for a unique, custom look. Our demon eyes are made in USA, and feature bright, full multicolor control and white!
They look great when paired with our RGBW boards, and can even be used on the same controller!
Click here to shop: RGBW™ Demon Eyes (Universal)
John C.
Diode Dynamics
Scion FR-S RGB MULTICOLOR DRL Bulbs: Plug & Play! Control W/Smartphone App Diode Dynamics Exterior Parts - Lighting 84 09-10-2021 10:25 AM
How to Install Subaru BRZ RGBW™ & Switchback LED Boards by Diode Dynamics JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 9 12-02-2015 09:11 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 12:09 AM
