Drives: 2015 FRS
Solution to squeaky windows?
silicon lubricant WD40:
did it work for ya? |
Well, @Zhangy, DO NOT use "silicon" ....... that will make your windows all gritty.
"silicone" is OK, and will make things slippery, when formulated to do so ....... ![]() Not all WD-40 is a silicone based material. The WD-40 that is silicone based will say so on the can. Yes, I have found that by putting a silicone substance on the weather stripping around glass will help keep the glass from squeaking. humfrz |
1) Clean it super well with rubbing alcohol
2) If it's deformed I'm pretty sure there is some TSB fix or fix that will be done under warranty.
| Squeaky clutch | V1B | Engine, Exhaust, Transmission | 24 | 06-16-2016 03:48 AM |
| Squeaky Chair | Selvedge | Issues | Warranty | Recalls / TSB | 19 | 01-30-2015 04:49 AM |
| RED FR-S with DG Squeaky Clean | Hamza7 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 02-01-2014 01:48 AM |
| Suffering from squeaky windows? | RYU | Issues | Warranty | Recalls / TSB | 35 | 01-12-2014 08:44 AM |
| Squeaky windows after rain. | Tien | Issues | Warranty | Recalls / TSB | 13 | 10-14-2013 03:23 AM |
