Old 12-16-2015, 12:13 PM   #1
speeddemon
Drives: Scion frs
OFT LC and FFS
Is the LC and FFS automatically on the newest version of the OTS maps (1.59)? Or do you have to go into RomRaider and activate them? My interpretation is that LC is already there at a default RPM and FFS is not enabled by default. Is that correct? I would like to play with these features but don't want to mess wih RomRaider.
Separate question, if the battery gets disconnected do you need to reflash your tune (in other words, does it reset the ECU?).
speeddemon is offline   Reply With Quote
Old 12-16-2015, 12:38 PM   #2
Who8myrice
Drives: Ap2
New stage1 map had LC already in it. Didn't try ffs so not sure about that.
But stage2 e85 from same version does not have LC for some reason.
Who8myrice is offline   Reply With Quote
The Following User Says Thank You to Who8myrice For This Useful Post:
speeddemon (12-16-2015)
Old 12-16-2015, 12:58 PM   #3
elBarto
elBarto's Avatar
Drives: Toyota GT86
LC is enable at most of the ROMs, stock at 5200rpm, to change it you need romraider. FFS is disabled. You need to edit it in romraider to enable it. You don't need to reflash with loss of power. It only needs to relearn the fuel trims and some other things. Best is to let the car idle for a minute before setting of after loss of power.
send using the coffeemaker
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
Old 12-16-2015, 07:13 PM   #4
steve99
Separate question, if the battery gets disconnectedg do you need to reflash your tune (in other words, does it reset the ECU?).
latest tunes are v2.07, the 1.59 are rearly old, if your editing use the new defs that come with the 2.07 tune back and read the romraider tips link below
no removing battery will only reset ecu learned values and cel codes the flased rom is permanent till reflashed.
Old 12-17-2015, 09:42 AM   #5
speeddemon
Drives: Scion frs
I am only seeing v1.59 on the website for downloads? The other options are for Crawford and ESC.
I tried to download romraider and when it is downloading it doesn't finish. I get a box that is blank and has (Made with IzPack-http://izpack.org/) in the bottom left corner and has "Previous" "Next" and "Quit buttons bottom right. If I try to hit next nothing happens.
And with the battery so I understand you correctly. After reconnecting it's like you flashed for the first time? So it will feel sluggish until in re learns?
Old 12-17-2015, 10:05 AM   #6
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
no idea what website you are trying to download tunes from, but on official site there isnt even 1.59 available anymore...only 2.07..
here's a direct link if you cant get it yourself: http://openflashtablet.com/Automotiv...S%20v2.070.zip
tdotBRZ is offline   Reply With Quote
The Following User Says Thank You to tdotBRZ For This Useful Post:
speeddemon (12-17-2015)
Old 12-17-2015, 10:16 AM   #7
speeddemon
Drives: Scion frs
http://openflashtablet.com/products/...ads/index.html
^^googled open flash tablet and hit the first link, this is like an old version of the official site.....weird...thanks for the update!
Old 12-17-2015, 10:29 AM   #8
tdotBRZ
tdotBRZ's Avatar
no worries. make sure to use the latest open flash manager software and latest template off the website (version 8.2), and if you're messing around with the files in romraider be sure to use the corresponding definitions file from 2.07 tune not old ones otherwise you risk bricking your ECU and tablet. Cheers
Old 12-17-2015, 10:31 AM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I had the same issue when I first got the tablet there seems to be two sites floating around, one a bit older than the other
Old 12-17-2015, 10:32 AM   #10
FRSBRZGT86FAN
This is the correct site that gets updated regularly bookmark this:
http://openflashtablet.com/Automotiv...ads/index.html
Old 12-17-2015, 10:53 AM   #11
speeddemon
Drives: Scion frs
Thanks alot everyone for the responses; very very helpful. I'm not great with this software stuff so I'm real nervous to mess around with Romraider..
