Old 12-13-2015, 07:53 AM   #1
azynneo
4.88 FD problems?
So.. I just past my 500 mile break in mark and changed out the gear oil.
I'd like to note the car is stupidly fast at accelerating now but theres a few things thats starting to happen.
Howling while turning, I posted this in the suspension thread but read everywhere on google that said it could be diff problem.
Air leak sound in the rear when I accelerate past 70 mph.
Downshift rpm increase with no increase in speed unless I put the foot WOT.
Squeaky sound on suspension while accelerating up hill / decelerating down hill.
All of this happened after I drove the car normally after break in period. 4-5k RPM highest shifts and the occassional 6k
Thoughts?
azynneo is offline   Reply With Quote
Old 12-13-2015, 09:09 AM   #2
FRS Justin
Drives: 2013 Asphalt FRS
Who built the diff??
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-13-2015, 03:37 PM   #3
azynneo
corner3garage
Old 12-13-2015, 09:42 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
Those symptoms sound like multiple issues. Are you auto or manual? Did you install any bushes or suspension bits at the same time? Are you using the factory LSD center or an aftermarket brand?
1974 TA22 Celica
2013 86 GT
Old 12-13-2015, 11:09 PM   #5
azynneo
a/t, no just coil overs, factory lsd
Old 12-14-2015, 02:11 PM   #6
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Out of all that you said "stupidly fast at accelerating" is the only part I paid attention to. I wish I knew someone close by with a A/T and 4.88
SUB-FT86 is offline   Reply With Quote
The Following User Says Thank You to SUB-FT86 For This Useful Post:
Impureclient (12-14-2015)
Old 12-14-2015, 11:53 PM   #7
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Thoughts?
What's the brand of diff oil?
You should use yoyota lsd 75-85 or 75-90 diff oil
Toyota86.ir is offline   Reply With Quote
Old 12-15-2015, 12:39 AM   #8
azynneo
this is wehat it sounds like on the high way now it howls on the highway. I used motul 300
AT problems? AJPG Engine, Exhaust, Transmission 8 03-08-2015 06:50 AM
DRL problems kk808hi Cosmetic Modification (Interior/Exterior/Lighting) 2 09-27-2014 12:33 AM
BRZ/FRS problems... jdmgevo Issues | Warranty | Recalls / TSB 19 08-07-2014 10:54 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
