| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Looking for toy roadster
Since selling my frs for a old 1999 alero.(free car) But I want to possibly get a fun second car that will be for weekend only for about 7500$ max. I am looking at a Toyota MR2 spyder 2002 or a bmw Z3 2000 2.8L. Both have there pros and cons. I am leaning towards the mr2 due to the weight mid engine and might be fun for the random auto cross or track day.
Sent from my LG-D851 using Tapatalk
2013 Series 10 FRS #553
Drives: frs
Miata
not playing cards
Although the mr2 ain't no caddy, if you're under 6', I agree with Teseo.
Assuming you're a DIYer, cost and ease of maintenance are also strongly in the Miata's favor.
I am really not looking at a mitia..
Site Moderator
Drives: ichi 86 Project
^This
But if I had to choose between MR2/MRS or Z3, I'll choose MRS |
not playing cards
Ditto.
I would say this might see 1 or 2 events per year if that. Also I like the idea if swaping a 2zz and getting close 200 HP in a 2100lbs car
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 12-12-2015 at 06:27 PM. |
Site Moderator
Just boost it instead of doing 2ZZ swap. It's cheaper and easier
#10 | |
#11 |
Drives: frs
Miata is dirt cheap, parts everywhere, easy to work. And still rwd
#12 |
Site Moderator
How you gonna by pass the ECU? Can you use 1ZZ ECU?
#13 | |
#14 | |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
It is also a myth that the MR-S is hard to work on. In fact, it is one of the easiest cars I have ever worked on. You just have to approach things slightly different. For example, the engine comes out the bottom instead of the top. The only thing difficult at all is doing something on the intake side of the engine. @OP. If you get serious about the MR2 Spyder then you should stop by Spyderchat.com and check out the buying guide (things to look for when buying). Make sure that you check to see that the pre-cats located in the exhaust manifold are intact. You can check them by pulling the two O2 sensors in the manifold and looking through the holes. Also check for oil consumption. The early 1ZZs are notorious for using oil and when you do not check the oil often enough......poof. For $7500 you might be able to find a 2ZZ swapped car. They do not have the oil issue and they come with 50 or so extra HP when using the Celica ECU. The only issue you might have is if you live in Ca where passing the visual part of the emissions testing is a bit of an issue.
So many modders have more cents than sense!
| 86 vs BRZ vs Roadster | GT86drifter | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 02-03-2015 06:32 PM |
| Has anyone come off a MC or out of a roadster ..? | humfrz | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 01-30-2014 10:06 AM |
| scion frs roadster | Rowolf | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 05-08-2012 12:12 AM |
