Old 12-12-2015, 04:11 PM   #1
jflogerzi
jflogerzi's Avatar
Looking for toy roadster
Since selling my frs for a old 1999 alero.(free car) But I want to possibly get a fun second car that will be for weekend only for about 7500$ max. I am looking at a Toyota MR2 spyder 2002 or a bmw Z3 2000 2.8L. Both have there pros and cons. I am leaning towards the mr2 due to the weight mid engine and might be fun for the random auto cross or track day.
Sent from my LG-D851 using Tapatalk
2013 Series 10 FRS #553
Old 12-12-2015, 04:49 PM   #2
Teseo
Drives: frs
Miata
The Following 2 Users Say Thank You to Teseo For This Useful Post:
Cole (01-02-2016), strat61caster (12-12-2015)
Old 12-12-2015, 05:01 PM   #3
Although the mr2 ain't no caddy, if you're under 6', I agree with Teseo.
Assuming you're a DIYer, cost and ease of maintenance are also strongly in the Miata's favor.
Old 12-12-2015, 05:15 PM   #4
jflogerzi
jflogerzi's Avatar
I am really not looking at a mitia..
Old 12-12-2015, 05:15 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Teseo View Post
Miata
^This
But if I had to choose between MR2/MRS or Z3, I'll choose MRS
hmong337 (01-02-2016)
Old 12-12-2015, 05:16 PM   #6
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
@Rampage
He'll more than likely have the best input on the MR2, even though his is swapped with a 2ZZ-GE.
Old 12-12-2015, 05:20 PM   #7
^This
Ditto.
Old 12-12-2015, 06:05 PM   #8
jflogerzi
jflogerzi's Avatar
I would say this might see 1 or 2 events per year if that. Also I like the idea if swaping a 2zz and getting close 200 HP in a 2100lbs car
Old 12-12-2015, 06:21 PM   #9
ichitaka05
Site Moderator
ichitaka05's Avatar
Originally Posted by jflogerzi View Post
I would say this might see 1 or 2 events per year in f that. Also I like the idea if swaping a 2zz and getting close 200 HP in a 2100lbs car
Just boost it instead of doing 2ZZ swap. It's cheaper and easier
Old 12-12-2015, 06:27 PM   #10
jflogerzi
jflogerzi's Avatar
Smog in CA. Rather not deal with this.
Old 12-12-2015, 06:28 PM   #11
Teseo
Drives: frs
Miata is dirt cheap, parts everywhere, easy to work. And still rwd
The Following User Says Thank You to Teseo For This Useful Post:
Ultramaroon (12-13-2015)
Old 12-12-2015, 06:33 PM   #12
ichitaka05
Site Moderator
ichitaka05's Avatar
How you gonna by pass the ECU? Can you use 1ZZ ECU?
Old 12-12-2015, 06:52 PM   #13
jflogerzi
jflogerzi's Avatar
Yes but I want something different a bit more unique. This not a dd. Plus the mr2 spider is pretty reliable as well. But so is z3 from what I have read
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 12-12-2015, 07:02 PM   #14
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Cheaper is debatable if you do the turbo right. Reliability is no comparison. The 2ZZ running on a stock 2000 Celica ECU will be factory dependable and problem free.
It is also a myth that the MR-S is hard to work on. In fact, it is one of the easiest cars I have ever worked on. You just have to approach things slightly different. For example, the engine comes out the bottom instead of the top. The only thing difficult at all is doing something on the intake side of the engine.
@OP. If you get serious about the MR2 Spyder then you should stop by Spyderchat.com and check out the buying guide (things to look for when buying). Make sure that you check to see that the pre-cats located in the exhaust manifold are intact. You can check them by pulling the two O2 sensors in the manifold and looking through the holes. Also check for oil consumption. The early 1ZZs are notorious for using oil and when you do not check the oil often enough......poof.
For $7500 you might be able to find a 2ZZ swapped car. They do not have the oil issue and they come with 50 or so extra HP when using the Celica ECU. The only issue you might have is if you live in Ca where passing the visual part of the emissions testing is a bit of an issue.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following 2 Users Say Thank You to Rampage For This Useful Post:
hmong337 (01-02-2016), ScoobsMcGee (12-17-2015)
86 vs BRZ vs Roadster GT86drifter FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 02-03-2015 06:32 PM
Has anyone come off a MC or out of a roadster ..? humfrz Scion FR-S / Toyota 86 GT86 General Forum 43 01-30-2014 10:06 AM
scion frs roadster Rowolf FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 05-08-2012 12:12 AM
