Old 12-09-2015, 06:47 PM   #1
yo.dur
Drives: 2013 Scion FRS
AFR Fluctuations with turbo kit
The problem is that im getting AFR fluctuations on a steady throttle, i even used cruise control to keep the throttle as uniform as possible but am still getting AFR fluctuations. These fluctuations in the AFR seemed to be caused by inconsistent MAF voltage readings. Heres a screenshot of what the tuner sent. The top log is my car and the bottom log is a stage 2 NA car used for a reference. You can see how much more linear the bottom log is in respect to the AFR and MAF voltage.
The tune is by speedfactory ft86, currently set for stock injectors, gt2871r, 270lph fuel pump, 91 oct, 3 bar map sensor for the full blown kit.
So far i have swapped the front o2 sensor, swapped the MAF sensor, cleaned MAF the connector, and checked the wires for physical damage to see if the sources of the problem.
Any suggestions on what could be causing this?
yo.dur is offline   Reply With Quote
Old 12-09-2015, 06:50 PM   #2
slowest86
Drives: slow frs
Boost leak?
slowest86 is offline   Reply With Quote
Old 12-09-2015, 07:08 PM   #3
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Well, if I had to hazard a guess, I'd like to see a photo inside and outside your MAF housing where it's welded to the charge piping.
Could be turbulence across the MAF, but I don't know what kit you're using or if it's a custom job.
Granted, I'm guessing at the MAF but it could be o2 sensor related. Who came first? Chicken or the egg. Either way it's hunting for equilibrium. It would really help to disable closed loop in ecutek and see a new data log.
Closed loop f*cks with proper diagnosis, and that would rule in / rule out the o2 sensor.
I doubt boost leak as you aren't in boost on that log. If it was a vacuum leak, you would have a ridiculous LTFT but it would / should stabilize.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 12-09-2015, 07:32 PM   #4
yo.dur
The turbo kit im using is full blowns. I inspected the charge piping before the install and everything checked out. I also did a boost leak test of the charge piping already and it all checked out, no leaks. Yeah the tuner and i were also thinking turbulence across the MAF. But he's tuned that MAF location several times before. There might be turbulence coming from the BOV though
Ive already replaced the front o2 sensor with a new one about a week ago, i also had an extra MAF sensor sitting around so i swapped that on as well. I was hoping those would solve it but to no avail. It might be some kind of electrical interference but thats a little beyond me.
Old 12-09-2015, 07:36 PM   #5
Spartarus
...Just add nauseum
Spartarus's Avatar
I would still try the same partial throttle data logging with closed loop feedback turned off. That will at least give a final determination on whether it is the MAF or the o2
-Spartarus
Old 12-09-2015, 07:57 PM   #6
yo.dur
alright sure ill try that later on tonight. Ive got a general driving log here as well using cruise control at 40mph. http://datazap.me/u/rasta42/log-1449...&zoom=694-1663 not sure if the graph will provide anymore insight into the problem but it does show fuel trims that are greater than 10%.
Old 12-10-2015, 09:54 AM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Does your BOV stay closed at idle?
Old 12-10-2015, 02:51 PM   #8
yo.dur
ill check that out right now. I have a boost gauge mounted which shows -17inHG give or take 1 at idle.
Old 12-11-2015, 09:28 AM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That is a little low. Perhaps you have a vacuum leak as well.
Old 12-11-2015, 05:18 PM   #10
yo.dur
Actually its holding -22inHG at idle, remembered it wrong.
Old 12-14-2015, 06:09 PM   #11
yo.dur
here are some logs i did this morning on speedfactory's tune. Car drives very smoothly, no noticeable bucks or hesitation. Just this AFR issue.
Cruise Control
http://datazap.me/u/rasta42/ft86crui...og=0&data=6-30
Idle at Operating temp
http://datazap.me/u/rasta42/ft86idle?log=0&data=6-30
Here are some logs on Delicious flash and go tune (speed density)
Idle:
http://datazap.me/u/rasta42/idledel2?log=0&data
Cruise control
http://datazap.me/u/rasta42/cclogdel...&zoom=673-1136
Old 01-02-2019, 01:07 PM   #12
mato2sk
Drives: Toyota GT86
I have an AFR fluctuation problem.
In open loop mode, AFR Error max + -1.5%.
But in closed loop mode, there are AFR fluctuations.
During idle speed, even at steady speed with cruise control.
I have my custom job turbo kit with the EFR 7163 Twin Scroll. 9PSI
Bosch MAP sensor 0281002437
AEM 340 Fuel Pump
OEM Injector.
I was looking for leaking of intake pipe, but I found nothing.
Photos of turbo kit design
mato2sk is offline   Reply With Quote
Old 01-02-2019, 02:28 PM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
How much/badly are they fluctuating? Some fluctuations in closed loop are to be expected.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-02-2019, 02:51 PM   #14
mato2sk
Drives: Toyota GT86
I added the log file.
https://datazap.me/u/mato2sk/log-154...a=4-5-11-14-15
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
oil pressure fluctuations Grip Ronin Engine, Exhaust, Transmission 13 01-19-2015 06:30 PM
Voltage fluctuations Andrew666 AUSTRALIA 7 03-19-2013 09:44 AM
