Old 12-09-2015, 01:34 PM   #1
Killerb92
Killerb92's Avatar
Drives: 2003 audi RS6>Now 2013 brzT Limited
Need help diagnosing engine noise and misfire
Hi guys I have a bit of a problem with my 2013 BRZ. I am getting some engine noise (I don't think it sounds like rod knock) that is consistent with engine speed. The car is also showing code P0301.
I have troubleshooted a bit so far, this is what I have done and the result:
1)swapped out coils packs to the new 2015 revised ones (TSB issued on 2013 ones)
2)swapped cyl 1 spark plug with cyl 3 spark and the issue still resided with a P0301
3)visually checked the spark plug that came from cyl 1 and it looked fine/normal but was soaked in fuel
My vehicle is modified -
-short block from MAPerformance (10.5:1 - forged pistons and rods)
-stock heads n valves but upgraded springs and retainers (skunk2)
-STS remote turbo system with 14ish psi waste gate
-tuned from Delicious
- probably some more just cant think of them right now
Here is a youtube video that I took to show the sound. Any help is greatly appreciated.
[ame="https://www.youtube.com/watch?v=eKZrAImJA88"]Jordo brz - YouTube[/ame]
Killerb92 is offline   Reply With Quote
Old 12-09-2015, 02:08 PM   #2
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Is delicious a tuning shop, or the ecu flash or replacement ecu? What are you using to control ignition advance and afr? Any data logging?
Good job checking plugs and coil packs first. Are the plugs stock, or are they one or two steps colder and gapped appropriately if adjustable?
Toyarzee is offline   Reply With Quote
Old 12-09-2015, 02:26 PM   #3
Killerb92
Killerb92's Avatar
Delicious is a tuning shop and they are remote tuning with ecutek having me send them datalogs and then they send me back revisions until it's fine tuned. It has not been fine tuned as of yet. Me and delicious have agreed to get it close and wait till I get the final parts (boost controller, inter cooler, fuel system, etc.) until the tune is completed.
The spark plugs are completely stock
Old 12-09-2015, 02:41 PM   #4
Killerb92
Killerb92's Avatar
I guess I could also explain exactly what happened:
Long story short I was messing with a mustang (about 750ish miles on this boost pressure setup before the cel popped). I was in second gear and I went wide open till about 7k rpms. I did not use the clutch but just let the engine die down itself - The CEL turned on while the engine was slowing down from that pull. I did not notice any noise or engine struggles at this time. When the engine went down to about 2500-3k rpms the CEL went away and everything acted normal. I stopped at the next red light (still everything normal) when the light turned green the CEL came back on and I noticed power loss. From that moment i pulled over checked for leaks or anything else that might be found visually - found nothing. I started the car back up and limped it home; about 3 blocks and this noise and problem has been there since.
Old 12-09-2015, 02:47 PM   #5
Toyarzee
Shibby!
Toyarzee's Avatar
14 psi on stock compression with no intercooler and partial remote tunes? Maybe it's just me, but I would never go wot under those conditions... it may have been difficult to hear pinging over engine and exhaust noise, but it is possible to exceed the knock sensors capacity if the detonation issue is great enough. I'm without sound at the moment, but I sure hope it's nothing serious and am interested to see what others have to say
Old 12-09-2015, 02:57 PM   #6
Killerb92
Killerb92's Avatar
stock compression is 12.5:1 I have lowered it to 10.5:1 - still a pretty high compression for a forced motor (no arguments there). The tune is good, when I mean finalizing the tune I am refering to advancing the timing to squeeze out more power.
I have been reassured from Delicious that the tune is not the problem - still a likely culprit until fully diagnosed... They also mentioned that they would like to see my car at 19psi boost controlled when I start looking into getting a revised tune.
I also agree with the non intercooler part - that was planned for next summer. As of right now Utah is always under 40 degrees and my charge pipe is a 8 to 9 feet long. Im thinking inlet air temp is not too big of a problem. Havent logged that on 14 psi but when I was breaking in the motor at 7 psi all my logs didnt show anything abnormal.
Old 12-09-2015, 04:05 PM   #7
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
your video wont load for me. I run stock plugs gapped to .020 at 30psi no problem on e85, i doubt you would have a plug problem on pump, even with the stock gap. I have had one coil fail but the other 3 are original and have been fine. you have valve springs so i doubt a rocker pin has walked out. you should have a hole in your valve cover if that was the case anyway. what do you run for oil? monitor pressure at all?
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 12-09-2015, 04:37 PM   #8
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Is that your BOV right next to your MAF?
If so, from your description of events, long rev down in gear under vacuum/no load. I think I know what happened.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 12-09-2015, 04:39 PM   #9
Killerb92
Killerb92's Avatar
Yes that's my bov and I think I put in 5w30 last change
Old 12-09-2015, 04:40 PM   #10
Spartarus
...Just add nauseum
Spartarus's Avatar
Originally Posted by Spartarus View Post
Is that your BOV right next to your MAF sensor?
If so, from your description of events, long rev down in gear under high vacuum/no load... I think I know what happened.
Edit: that's a rhetorical question.
I would move that post-haste. I bet money that the spark plug was soaked in fuel because the MAF still saw a ton of airflow over an extended rev-down, (as the BOV was likely hanging open for a while) and the engine ran richer than hell.
If that is the case, then you are going to have serious AFR problems every time that valve opens.
As for the specifics on the damage you may or may not have caused, I have no idea. Just speculating on the initial cause. I have no audio at the moment.
-Spartarus
Old 12-09-2015, 04:54 PM   #11
Toyarzee
Shibby!
Toyarzee's Avatar
Good catch. I hate MAF sensors now and always switch to a standalone ecu and map sensor when converting to FI for reasons such as this
Old 12-09-2015, 05:09 PM   #12
Killerb92
Killerb92's Avatar
that makes sense. Let me try and make sure I am getting this correctly.. to solve this in the future I should move the bov farther back from the MAF or should I move the MAF closer to the intake? If moving the bov back; how far are we talking about?
STS so far is the worst decision I have made on my car. Nothing but problems so far and they went out of business right after I purchased the kit so finding technical help is hard. I have been playing around with the idea taking it to a local FAB shop to have them cut everything up and make a custom front mount setup.
Old 12-09-2015, 05:41 PM   #13
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
TOTALED!
fumanchu1 is offline   Reply With Quote
Old 12-09-2015, 05:41 PM   #14
fumanchu1
Also you should sell me the engine for dirt cheap since it's totaled
Engine/Transmission noise N1rve Issues | Warranty | Recalls / TSB 48 05-06-2018 10:17 PM
Cold Engine Knock/Misfire FR Sports Engine, Exhaust, Transmission 2 10-02-2015 12:07 AM
Really odd engine noise Deadspool Engine, Exhaust, Transmission 52 03-10-2014 12:43 PM
Another Engine noise Vegas86 Issues | Warranty | Recalls / TSB 4 10-09-2013 12:30 PM
Engine noise somejace BRZ First-Gen (2012+) — General Topics 4 09-19-2013 06:39 AM
