Old 12-09-2015, 10:13 AM   #1
Eighty 6
Newbie
Drives: Gt86
No headlight adjustment on these cars?
Is it just my car or do all of these cars not have headlight adjustment switch? My lights beam is a bit low.
Eighty 6 is offline   Reply With Quote
Old 12-09-2015, 11:16 AM   #2
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Depends which lights you have on yours. The BRZ has an adjustment switch, but the standard FRS does not. (The special editions might, if they use the BRZ headlights.)
ashtray is offline   Reply With Quote
Old 12-09-2015, 11:22 AM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
well based on your avatar info you have GT86 (depends on your region as GT86 also come with base headlights)..you should have an adjustment knob on the left side of the dash..If you have a FRS there should be an adjustment knob/screw on the headlight....can't confirm i don't have base FRS headlights.
Old 12-09-2015, 11:39 AM   #4
Eighty 6
Newbie
Drives: Gt86
Thanks. Definitely no headlight adjustment switch inside, so it must be on the light itself. They weren't kidding when they said this car took you back to the 80's and 90's.
Old 12-09-2015, 04:38 PM   #5
sabajin
Drives: ´15 GT86
This might solve the problem of our cars:
https://www.japanparts.com/parts/detail/44832
sabajin is offline   Reply With Quote
Old 12-10-2015, 07:33 AM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
There's probably going to be a 10mm or 8mm bolt on the back of the headlights that adjusts the height if I remember correctly for the FR-S halogens at least, I imagine the housing is similar. For my winjets it's an 8mm.The right way to aim it (in the U.S. at least) is to park in a place that has 25 feet of free space from a wall and then mark the exact center of the headlights parallel to the wall with tape or something on the wall. Reverse the car 25 feet away from the wall then aim the headlights to the mark on the wall and you should be good. That's what I've done with my HIDs in the "JDM" replicas and haven't blinded oncoming traffic and I can also see at night!
Old 12-10-2015, 03:26 PM   #7
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Wut? My 10 series is the first car I've owned with an interior adjustment switch... not even my dad's 2011 M3 has interior headlight adjustments...
Cartman is offline   Reply With Quote
Old 12-10-2015, 03:35 PM   #8
NyC Zn6
NyC Zn6's Avatar
Thats because your father's M3 has adaptive headlights which auto adjust left to right...the up and down is on the headlight itself lol
Old 12-10-2015, 03:48 PM   #9
FRSBRZGT86FAN
Even the E46 M3 had adaptive headlights, it was a big deal back then, and they still had a height adjustment knob the computer only self levels from left to right and also makes sure that height stays the same relative to suspension geometry
Old 12-10-2015, 04:09 PM   #10
NyC Zn6
NyC Zn6's Avatar
Old 12-10-2015, 04:32 PM   #11
Cartman
Cartman's Avatar
My E39 has that hight sensor too, but you still have to adjust the headlights manually at the headlight... not by a knob inside.
Headlight assembly adjustment ARTBRZ BRZ First-Gen (2012+) — General Topics 2 08-13-2015 12:19 AM
Headlight assembly adjustment ARTBRZ DIY (Do-It-Yourself) Guides 0 08-11-2015 11:04 PM
Winjet Headlight adjustment help 7M-King Cosmetic Modification (Interior/Exterior/Lighting) 2 09-07-2014 08:52 AM
Manual "on-headlight" projector adjustment. Simon99 BRZ First-Gen (2012+) — General Topics 10 02-02-2014 03:49 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
