Old 08-11-2015, 11:21 PM   #1
ARTBRZ
Aloha!
ARTBRZ's Avatar
Headlight assembly adjustment
Had my passenger headlights replace and the tech didn't adjust it. I can't find pictures where the manual adjustment is located. Anyone know where it is?
ARTBRZ is offline   Reply With Quote
Old 08-11-2015, 11:57 PM   #2
ARTBRZ
Aloha!
ARTBRZ's Avatar
Found the answer in a YouTube video. If anyone is curious. It requires an 8 mm socket. Counter clockwise raises the cutoff.
[ame]http://youtu.be/hye_OnwEyTs[/ame]
Old 08-13-2015, 12:19 AM   #3
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
The teeth are made in such a way that a positive or "Phillips head" screw driver aimed straight down will catch those teeth and turn the adjuster without a socket set.
Pretty normal for HID adjustment.
MGPAX is offline   Reply With Quote
Headlight assembly adjustment ARTBRZ DIY (Do-It-Yourself) Guides 0 08-11-2015 11:04 PM
For Sale: OEM BRZ Headlight Assembly Pair BRZoomTX Exterior Parts (Aero, Lighting, Etc.) 8 07-20-2015 01:31 PM
Winjet Headlight adjustment help 7M-King Cosmetic Modification (Interior/Exterior/Lighting) 2 09-07-2014 08:52 AM
Part # for 10 Series Headlight Assembly only? FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 1 05-13-2014 05:03 PM
Rust on bolt on headlight assembly slicktop Cosmetic Modification (Interior/Exterior/Lighting) 0 12-13-2013 09:11 AM
