Old 12-09-2015, 07:45 AM   #1
mcrane
mcrane's Avatar
OFT Battery Disconnect Tune?
This may be a stupid question, but I figured I would post it anyway for future users if they are also curious...
Once my ECU has been flashed with the OFT, would disconnecting the battery or accidentally having the battery die on me revert the ECU back to a factory tune?
I would think not since the new tune would be stored within the ECU after flashing. The only way to get the stock tune back would be to flash it back, is my understanding.
But again, just a curiosity and additional forum info for future customers.
- Thanks Guys
mcrane is offline   Reply With Quote
Old 12-09-2015, 08:16 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Removing power to the ECU will reset info like LTFT and IAM etc. However you are correct that the tune is not removed. You would basically end up as if the tune had been flashed for the 1st time, meaning pedal/throttle learning needs to be carried out etc.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
mcrane (12-09-2015), Mr.Impreza (11-18-2017)
Electric dies when trying to start, disconnect/reconnect battery starts fine gregdobs Issues | Warranty | Recalls / TSB 10 05-12-2015 10:37 AM
How to Disconnect battery?!?!?! aakash Cosmetic Modification (Interior/Exterior/Lighting) 2 01-29-2014 01:47 PM
Issue after battery disconnect Audio related. Mako Issues | Warranty | Recalls / TSB 4 07-10-2013 09:29 PM
Disconnect battery for all LED installation? husker741 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-30-2013 03:25 PM
Winter battery disconnect Skye Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-23-2012 12:28 AM
