Boost Creep
Drives: 2016 HyperBlue BRZ
2016 Aftermarket HU - Stock Wiring
So I just tore open the dash to install my Pioneer HU and everything is connected but the door speakers don't work. Rear and dash tweeters and mids work great. I suspect there's a factory amp, but there is no wire in the #9 position of the 10-pin harness. The #8 position I have connected to the antenna turn on wire of the HU. I've also tested it with switched 12V to be sure. I'm not sure where to go from here.
Drives: FRS
make sure your remote out from the HU is wired to the harness that goes to the car to enable the stock amp.
Drives: 13 Sc10n FR-S
Pin 9 should be the amp signal wire Don't know if it's a 5v signal though ![]() SC10N driver |
I personally just took the amp out and jumped the pins
SC10N driver
Boost Creep
I have that same manual, on the phone I'm posting from, in fact. It's apparently not fully applicable to this model year.
Wait your car is a 2016?
SC10N driver |
Then it's pin 9 of the extra connector that doesn't get used
#10 |
Sorry I was looking at the 2013 diagram for my car but it changes from connector "B" to "A" on the 2016
#13 |
Yup yup glad I could help, enjoy
SC10N driver |
#14 |
Drives: GT86 High
What kind of manual is this?
| Using factory wiring for aftermarket fog light kits | Wizardhat | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 12-05-2021 04:05 PM |
| Aftermarket Headunit to Factory wiring harness? | Dadhawk | Electronics | Audio | NAV | Infotainment | 9 | 11-13-2015 11:23 AM |
| Stock amp/wiring questions | Matey | Electronics | Audio | NAV | Infotainment | 5 | 08-22-2015 08:28 AM |
| FRS aftermarket head unit installation - wiring | MindtheGap | Electronics | Audio | NAV | Infotainment | 35 | 01-14-2013 09:00 PM |
| P8400 Aftermarket deck HELP NEEDED WITH WIRING | iamkyle | Electronics | Audio | NAV | Infotainment | 1 | 01-13-2013 03:41 AM |
