Old 12-02-2015, 11:56 PM   #1
Knshro13
Drives: 10 series FRS
Trust/Greddy FRS/BRZ/86 Dog Box Transmission
I had the opportunity to test out Trust Racing's new 86 build for Toyo Tires. The car was equipped with a Greddy Performance 2.1L stroker kit, a Greddy T620Z Turbo kit with 550whp, and the revised Trust Racing 6 speed Dog box.
I won't go into too much detail since the photos can tell a lot but the gear set is made to fit in the stock transmission case.
With a ton of clutch kicks in 4th and 5th gear on Toyo's sticky Trampio R1R, the gear set was basically unharmed upon inspection. 4th gear is the common culprit for those of us with higher HP numbers and sticky tires. We shaved the reverse gear, and made 4th gear a lot thicker.
The gears are helical cut for two reasons. One: its quieter for street use (although i am sure some will say they like the gear whine), and two: helical cut gears are stronger than straight cut gears.
Since I am not a vendor here, I won't mention any pricing, but from one fellow FRS owner to others, I just wanted to let you guys know that we now have an option! no more broken 4th gears!
You can comment below for any questions, or contact Greddy Performance.
Knshro13 is offline   Reply With Quote
The Following 15 Users Say Thank You to Knshro13 For This Useful Post:
86drift (01-13-2016), BatStig (01-11-2016), Bonburner (02-07-2016), chaoskaze (02-12-2016), DarkSunrise (12-03-2015), Doozer (01-22-2016), Drakiv (01-22-2016), JDKane527 (12-03-2015), kbye (12-03-2015), MJones_RB (04-06-2016), raven1231 (12-03-2015), swarb (12-03-2015), Ultramaroon (12-03-2015), whataboutbob (02-17-2016), ZionsWrath (12-03-2015)
Old 12-03-2015, 12:45 AM   #2
raven1231
How long until the Sbd version comes out?
The Following 12 Users Say Thank You to raven1231 For This Useful Post:
504 (02-12-2016), Dream20b (01-22-2016), Fakk (02-15-2016), Fred E (12-03-2015), killboy (02-12-2016), mrk1 (02-11-2016), Nessal (02-12-2016), nickmerronesucks (02-11-2016), Nightbringer (07-18-2020), thunderlights (12-03-2015), weederr33 (02-12-2016), wparsons (01-23-2016)
Old 12-03-2015, 01:51 AM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
killboy (02-12-2016), raven1231 (12-03-2015)
Old 01-11-2016, 12:55 PM   #4
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Anyone have more info on the trans gears?
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 01-22-2016, 02:05 AM   #5
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
off topic, but what the fuck is going on with those strut mounts?!? Guessing longer lower control arms and tie rods for more steering angle which necessitates moving the strut more outboard?
Got any shots of the front suspension?
Decay107 is offline   Reply With Quote
Old 01-22-2016, 02:41 AM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
T__________T
You suck
Old 01-22-2016, 05:56 PM   #7
Knshro13
yep exactly. This car has a wisefab steering kit, which utilizes longer lower control arms. The struts are moved outwards equal distance to the lca.
ill upload more photos of the car in a bit.
The Following User Says Thank You to Knshro13 For This Useful Post:
Drakiv (01-22-2016)
Old 01-22-2016, 11:03 PM   #8
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Finally! I need this set........
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 01-23-2016, 01:12 AM   #9
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
It also relocates the steering rack inside the front crossmember, rather than behind it, and replaces the knuckles.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 02-07-2016, 03:29 PM   #10
Lonewolf
Lonewolf's Avatar
Drives: Moped
A mention and some more pics of the dogbox here:
http://greddy-usa.blogspot.com/2016/...uto-salon.html
The Following User Says Thank You to Lonewolf For This Useful Post:
Old 02-11-2016, 04:30 PM   #11
bem75
Round 3 Racing
bem75's Avatar
Drives: Scion FR-S race car
Trying to get information from Greddy on this dog box has been difficult. Anyone have any info, like price or availability?
bem75 is offline   Reply With Quote
Old 02-12-2016, 12:13 AM   #12
Lonewolf
Lonewolf's Avatar
Drives: Moped
@Knshro13
Knshro13 (02-12-2016)
Old 02-12-2016, 02:20 AM   #13
Knshro13
I saw your PM.
Ill get in touch with you.
Old 02-13-2016, 02:21 PM   #14
Knshro13
Ive been getting a few DMs regarding this kit.
I am not a vendor nor am i directly selling these gear sets.
You guys can contact Greddy at 949.588.8300 and ask for either Mike or Kenji.
Meanwhile, here is some info on some questions i have been receiving.
Gear ratios for the gears:
1st 2.6805
2nd 1.8514
3rd 1.4017
4th 1.1529
5th 1
6th 0.8716
At this moment, customs gears are not available. You can however order spare gears or misc. replacement parts.
Here is a list of OEM toyota parts needed to complete the dog box. These parts are order via Toyota parts department.
SU003-03499 6th gear thrust washer
SU003-03923 4th gear washer set
SU003-03521 3rd gear needle roller bearing
SU003-03522 input shaft bearing
SU003-03524 6th gear needle roller bearing
SU003-03525 counter gear front bearing
SU003-03526 output shaft bearing rr
SU003-03527 input shaft bearing fr
SU003-03550 force washer retaining snap ring
SU003-03587 counter gear front bearing snap ring No.1
SU003-03588 snap ring (need 2)
SU003-03640 slotted spring pin
SU003-03641 gear thrust washer straight pin
SU003-03874 gear shift fork shaft no. 5
SU003-03890 force washer retaining ring
SU003-03924 shaft snap ring
SU003-03925 counter gear front bearing snap ring No. 2
SU003-03926 6th gear shaft snap ring
SU003-03927 front bearing shaft snap ring
SU003-03928 transmission clutch hub No.3 shaft snap ring (need 2)
SU003-03908 1st shift restrict ball
The Following 5 Users Say Thank You to Knshro13 For This Useful Post:
Andew727 (04-12-2016), celek (02-13-2016), Drakiv (02-15-2016), Hawk77FT (02-16-2016), whataboutbob (02-17-2016)
Greddy/Trust T518Z Turbo Kit Owners rocketbunny86 Forced Induction 126 05-24-2024 04:02 PM
Greddy / Trust Turbo Kit (Video and Pictures) BPAuto Forced Induction 62 03-18-2016 07:04 AM
Opinions Needed on Greddy/Trust Spoiler Primeraman Cosmetic Modification (Interior/Exterior/Lighting) 4 11-22-2014 11:09 PM
Greddy Trust Wings question Liselotte Cosmetic Modification (Interior/Exterior/Lighting) 4 05-11-2014 05:46 PM
Greddy Trust Wing pghfan19 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-31-2013 09:35 PM
