Old 11-28-2015, 08:19 PM   #1
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
What is good boost for the FA20 now?
I am really out of the loop with the current FI scene for the twins. How much boost are people running on the stock engine safely now? Also, what is the Automatic transmission rated at boosted?
Thanks,
Exhaust is offline   Reply With Quote
Old 11-28-2015, 08:31 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I'm personally not going to play with fire. I'm keeping my GTX30 @ 7PSI until my motor build is done.
Others are pushing well over 400rwhp on stock and haven't had a problem.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-28-2015, 08:42 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thanks,
It really depends still. Btw trannys should be rated in foot pounds of torque not boost haha!
Old 11-28-2015, 08:44 PM   #4
Northwest86
Drives: Velocity Orange 86 GT
7-10ish is the safe zone. Where you have a 95% chance of being all good maintaining the fact that the car is maintained well and the tuner has any idea on what he's doing. After that you are getting into dyno queen/highway pull kind of power. 250-300kw is the point where if you are racing/tracking/driving hard alot, you will start to have problems frequently. It depends on your tuner for base reliability then driving habits. Basically if you can get the power on a stock fuel system, it's pretty reliable. (which is about 180kw or 220-230 on the higher reading dynos)
Northwest86 is offline   Reply With Quote
Old 12-01-2015, 12:31 AM   #5
BostonDave91
Drives: 2016 frs
I plan to use my car as a daily driver and visit the drag strip a few times a month. I'm thinking a borg warner EFR 7670 from what I hear it's good for 400+ hp. I'm not even going to mess around and I'll put a new clutch in at the sametime. Any thought on this would be great...
BostonDave91 is offline   Reply With Quote
Old 12-01-2015, 05:13 AM   #6
Northwest86
You will need a new clutch for sure. For a daily driver I'd say 7-9 psi is safe. Assuming that your tuner is good. More is easily feasible but at that point with the wrong tuner it can go at any time. Yeah that turbo will easily do what you want. Turbo selection is complex and a very experienced tuner on the 86 platform can really help with that.
Old 12-01-2015, 11:58 PM   #7
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
what boost controller are my turbo friends running? And how do you guys set it up?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 12-02-2015, 12:21 AM   #8
Mild2Wild
Drives: Firestorm FR-S
If you visit the drag strip more than a couple times without your entire drivetrain hating you I will be surprised. It's not just the clutch you'll be putting incredible pressure on; with 400+hp (and the accompanying torque) launches at the drag strip axles will break quickly and your transmission will probably fail soon, too.
Mild2Wild is offline   Reply With Quote
Old 12-02-2015, 12:30 AM   #9
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
1 million psi
hmong337 is offline   Reply With Quote
Old 12-02-2015, 09:00 AM   #10
mrk1
Drives: Sterling BRZ Ltd
I'm running a TurboSmart eBoost2, it's separate from the ecutek tune so I can easily adjust on the fly. If you only want a hi and low boost setting that can be done with just a boost solenoid wired into ecutek.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 12-02-2015, 12:02 PM   #11
BostonDave91
Drives: 2016 frs
Id like to have between 325 and 350whp. What Axles are people running on there cars. When you say transmission in think automatic. Do you mean my rear end and gears will blow up? Yes im a noob sorry for the stupid questions.
Old 12-02-2015, 12:11 PM   #12
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
After reading forum posts it seems max 9psi is safe but it depends to tune.
Be careful about remote tuning (boost).
Toyota86.ir is offline   Reply With Quote
Old 12-03-2015, 05:23 AM   #13
Northwest86
Running wastegate at this time as there were none of the boost controllers I wanted in the country. But I will be running a Plex PBC
Old 12-03-2015, 02:55 PM   #14
coyote
coyote's Avatar
Drives: Slowly
I bought all Plex's PBC Pros last month. They will have new stock in late January.
Sent from my Nexus 6 using Tapatalk
coyote is offline   Reply With Quote
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
a really really good post about the FA20 internals BRZPDX Northwest 2 03-30-2014 01:27 PM
Is going all catless on a na fa20 motor such a good idea? Astroboy Engine, Exhaust, Transmission 105 09-14-2013 09:48 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 03:33 PM
