Old 11-28-2015, 06:52 PM   #1
shellslinger
Drives: Whiteout FRS
Driver Side Front Wheel chirping
Hey guys,
I've been trying to figure out this issue. After replacing both front and rear pads and rotors I'm getting this chirping sound on the driver side. It only is apparent going above 60mph. I put grease on the back of the shims on the new pads. I'm using winmax and centric rotors.
Any ideas?
Thanks all
shellslinger is offline   Reply With Quote
Old 11-28-2015, 08:01 PM   #2
humfrz
hmmmm.........did you "bed" the new brake pads ..... ??
humfrz
Old 11-28-2015, 08:25 PM   #3
shellslinger
humfrz
Yeah I followed the insurrections of 7-10 stops from 50-12mph then from 75-12mph
Not sure what else to do
Old 11-28-2015, 09:30 PM   #4
DJCarbine
Thupercharged
DJCarbine's Avatar
So the chirping is constant at 60mph, with no brakes?
If you depress the pedal slightly, does it go away completely?
2013 FRS
Vortech V3 11psi
Old 11-28-2015, 09:51 PM   #5
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
As dumb as it sounds - check the tire for abnormal wear and/or nails. Remove wheel and remount. Dont use gun - and torque properly (star pattern). See if that helps.
SpectreRT is offline   Reply With Quote
Old 11-28-2015, 10:29 PM   #6
humfrz
....and while you have the wheel off, you might check to make sure the calipers are tight.
humfrz
Old 11-28-2015, 10:45 PM   #7
shellslinger
Yeah as soon as I press the brakes it goes away.
Old 11-28-2015, 10:46 PM   #8
shellslinger
Thanks guys I will try tomorrow and report back. Thanks!
Old 11-29-2015, 12:58 AM   #9
humfrz
It could be that a caliper is sticking....??
humfrz
Old 12-03-2015, 06:21 PM   #10
shellslinger
humfrz
Fixed issue, appears that I did not lube the shims enough
Old 12-03-2015, 06:51 PM   #11
humfrz
humfrz
Wtb: SWP driver side front fender Vten Want-To-Buy Requests 0 06-01-2015 08:23 AM
Clicking noise in wheel area, driver side Rabbit of Caerbonnog Issues | Warranty | Recalls / TSB 19 02-18-2015 01:59 PM
WTB: Driver Side OEM Front Lower Control Arm 86nub Want-To-Buy Requests 1 09-08-2014 12:44 AM
OEM Driver Side Wheel Scraping? Parikh1234 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-17-2014 04:29 PM
